IE7-- should I allow it to install? Windows downloaded an update for interent explorer 7, but I have heard that one shouldn't download it. Is this idle MS bashing, or are there real problems with it? BTW-- I would use firefox, as I am aware of its value but unfortunately, we are using netscape 'high-speed' dial-up as we can't get true high-speed here. and the max line speed is 28.8. Firefox does not work well with the dialup accelerator, and prevents access to many sites. |
I've been running it for over a month now and I haven't had any issues. If you're an IE person you definately want this upgrade.... tabbed browsing takes a while to get used to but it's worth it, pop up blocker works, and there is a new anti-phishing setup as well. |
Phising is available for firefox too. IE7 FINALLy after what 10+ years decides to use tab browsing? Firefox for me |
I am running it now, and I haven't found anything awful about it- I also turned the phishing feature off as I can't afford to sacrifice any more speed. |
I agree about tabbed browsing, why the hell did it take MS this long? I know what you mean about FF on dial up it's a pain. |
Working for an ISP I've seen lots of issue where IE7 doesn't handle Flash Active X controls very well. I've also seen where if you have Flash Player 9 already installed and you go to a Flash based site you get a warning telling your to upgrade your Flash. Myself I stick to Firefox. |
I've been getting daily random shut-downs with ie7 for some reason-- haven't noticed the flash problem yet. |
I've been using it on the wifes laptop for a while now and no major problems yet, but I do have one issue with it and that is mem usage. Man this thing eats mem. Usaully after about 30mins of surfin and tabbin i have to use cacheman to recover mem cause it is using btween 80 and 100 mgs of ram:( Wifes laptop only averages around 150 mgs of free mem so it tends to slow things down. Just gotta add more mem I guess. |
Wow-- yeah, I just checked, and it's using 125 right now |
I use it along with FireFox. I've noticed that it has issues with a few websites I visit and places like our forum, the iTrader tab doesn't work properly but does in IE6.:angry2: |
| All times are GMT -7. The time now is 02:33 PM. |
