Old April 13, 2009, 03:27 PM
element291's Avatar
Default Quickest AVI to DVD + Burning software?
The title says it all.
I am looking for the best avi to dvd converting software. I would like one that does it all, (convert and burn).
Let me know what you find the best and quickest program...
I have tried a few, and I have also noticed on a few that I get audio lag, and after about 5 minutes of watching the movie, it gets unbearable because the audio is so out of sync. I cannot watch a movie, when their mouth dont move when the audio is being played.
Anyways, let me know your opinions, and what you use!
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old April 13, 2009, 04:18 PM
JD JD is online now
VSO ConvertXtoDVD. Only one I know of and use.
Old April 13, 2009, 05:34 PM
Shadowmeph's Avatar
a good free on is deVEde I use it when I am on Linux but it works just a good in Windows also + like I said it is free and you don't need to worry about pirated software or potentual virus's if you aer using cracked software DeVeDe I use it and it is pretty fast
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old April 13, 2009, 06:49 PM
element291's Avatar
I used convertxtodvd and encoded/burned a 2 hour avi in 16 minutes. Not bad I'd say.
Old April 13, 2009, 08:48 PM
Bones's Avatar
ConvertXtoDVD is the best I've ever used. Does a pretty good job fairly quickly (depends on your machine's performance) and best of all, it's really easy to use ... essentially, one click and your done.
Old April 14, 2009, 01:07 AM
Realityshift's Avatar
+1 to convertxtoDVD works great, its fast, does an awesome job of syncing sound and the newer version have some decent built in menus. Deffinetly the best program I have used to date.
The Builders Hammer
Old April 14, 2009, 09:36 AM
JD JD is online now
And it only gets faster if you have a quad-core since it's multithreaded
Problems Burning DVD from Video Editor - Vista Problem? jgerber O/S's, Drivers & General Software 0 March 22, 2009 09:25 PM
Looking for software recomendations for DVD ripping Cowinacape O/S's, Drivers & General Software 4 November 24, 2008 09:14 PM
Need a burning software to backup my movies? mazabe O/S's, Drivers & General Software 8 November 19, 2008 08:28 AM
Best DVD Burning/Ripping Software? bojangles O/S's, Drivers & General Software 3 October 11, 2008 10:43 AM
DVD-RW burning time... omgwtf Troubleshooting 7 April 13, 2008 08:11 AM
