Old April 13, 2009, 09:45 AM
Default XP Pro 32 bit - Upgrade too Vista Ultimate 64 bit
I've got a system that came preloaded with Vista Home Premium and I had it as a dual boot with XP pro on a seperate HD. However, last week, I upgraded the XP Pro too 64 bit Vista Ultimate.
After the upgrade was done, I noitced that the install created two folders, one named Program Files (86) and the other is Windows.old. I assume that these folders contain the XP OS and program files. My question is, can I delete those two folders without having to worry that my system will crash or something? There is nothing on the XP Pro install that I'm worried about losing, just want to make sure I can safely delete the two folders.
You'll see the two extra folders in the attachment
Thanks for any info!
Old April 13, 2009, 09:57 AM
3 of 7's Avatar
Do not delete the Program Files X86. It's the folder there Vista will install all the programs that aren't written specifically for the X64 architecture . As for the Windows.old folder I think your spot on about it having the old windows install on it.
You could just rename it till you need the space in case there is anything you want from it.
Nature always sides with the hidden flaw
Old April 13, 2009, 09:59 AM
JD JD is offline
I think you can also run Disk Cleanup and it'll remove the according old OS files for you.
Old April 13, 2009, 01:22 PM
bojangles's Avatar
I would personally do a fresh install and see if any of your old programs are compatible at the 64-bit level. But yeah that windows.old are most likely the old XP files. Store it on an external HDD or a partition if you want.
Old April 13, 2009, 01:25 PM
Considering like 90% of software is still 32bit compatible issues don't exist.
Old April 13, 2009, 03:34 PM
I've been running XP64 for a few months now and these are the programs I've installed that are 64bit:
7-zip (which I dislike and am probably going back to WinRAR)
QuickSFV (which I don't understand why it's 64bit, but it's there so I'm listing it)
Ventrilo (see QuickSFV)
Everything else is in the Program Files (x86) folder
A bit of an upgrade - just looking for a second opinion. Andy New Builds 11 April 17, 2009 09:16 PM
64 Bit Vista Ultimate and Office Ultimate 32 Bit tyreman O/S's, Drivers & General Software 5 March 22, 2009 04:54 AM
[WTB] Looking For A Copy Of Vista Ultimate 32/64-bit, ASAP :) jeffyp17 Buy/Sell & Trade 4 November 22, 2008 11:25 AM
Vista Home Premium 32 bit to Vista Ultimate 64 bit 334th_Frenchie O/S's, Drivers & General Software 4 September 9, 2008 07:45 PM
been bit by the upgrade bug again ;) ebdoradz Off Topic 2 June 25, 2008 03:19 PM
