<~----> does your vista 64bit comes with - Hardware Canucks
Old April 9, 2009, 03:27 PM
Default does your vista 64bit comes with
does your vista 64bit comes with a folder called "x86 program file" on c drive?
Old April 9, 2009, 03:38 PM
all 64 bit Windows OS do.
simply because 99% of software is not 64bit and it needs the legacy directory to work.
Old April 21, 2009, 11:14 AM
norfolk's Avatar
Thank you for clearing that up,I was wondering that as well.
Old April 21, 2009, 11:34 AM
Jake_HT's Avatar
You gotta add the "Porn" folder yourself, though.
http://jakeht.deviantart.com/
Old April 22, 2009, 08:24 PM
Bones's Avatar
Could also be "x86 Porn"
Old April 23, 2009, 03:58 AM
gingerbee's Avatar
already added to windows 8
Old April 23, 2009, 08:48 PM
Bones's Avatar
Good to know ... Finally, they are adding things that are of some real use.
64bit OEM Vista on multiple computers? Evylldemon O/S's, Drivers & General Software 17 October 3, 2009 11:52 AM
XP? Vista? 32bit? 64bit? 7? RainMaker O/S's, Drivers & General Software 30 January 13, 2009 06:08 PM
Vista 32bit or 64bit for gaming cndian O/S's, Drivers & General Software 54 December 10, 2008 05:47 PM
Is it time for Vista 64bit? magictorch O/S's, Drivers & General Software 41 July 19, 2008 12:50 PM
Vista 64bit vs. XP 32bit 4GB RAM bench comparo Eldonko O/S's, Drivers & General Software 13 May 14, 2007 01:09 PM
