Old April 9, 2009, 07:40 AM
Default Laptops and OS's
Hi, Anyone familiar with the major brand names out there, HP, Dell, Acer laptops operating systems?
My concern is I want XP Pro on whatever I buy and they all come Vista. I need the XP for compatibility with others at office. Is it a no brainer to install XP on an laptop from these manufactures?
Code:
Old April 9, 2009, 08:22 AM
Shadowmeph's Avatar
Maybe just ask them for XP instead
Old April 9, 2009, 09:24 AM
Thund3rball's Avatar
On Dell some of the business class machines come with a Vista downgrade option meaning you get XP installed and the unit comes with media for both XP and Vista.
The Dell Online Store: Build Your System
Doing a DIY downgrade to XP on any laptop really depends on driver availability. It is possible and there are many guides out there pointing you to drivers for particular models but I fear many of the newest consumer models may have les and less XP compatibility.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old April 9, 2009, 10:14 AM
gingerbee's Avatar
if its vista ready i think its xp ready
Old April 9, 2009, 01:41 PM
^^ Not true. Laptops are not desktops... drivers for Vista doesn't mean there's drivers for XP. You may lose some functionality by downgrading if there are no supported drivers for those functions (i.e. media keys, hot keys, other hardware etc...).
Desktop:
See the drop down!
HEATWARE
Old April 9, 2009, 01:50 PM
JD JD is offline
What about running XP virtually in VirtualPC or the like? Though that would depend on what you require XP for.
Old April 9, 2009, 02:11 PM
IBM I think is one of the last few who still laptops with XP you could also check out Acer.
Old April 9, 2009, 03:04 PM
Lenovo is pretty damn near close to the only manufacturer left.
H3LL claims it, but they don't actually have any (official) XP drivers.
I spoke to their "Support" (which was useless I might add) and they basically said that there's no such thing as a downgrade as there's no drivers.
Oh and according to "support" if I bork my OS somehow I have to repurchase it.
Old April 9, 2009, 04:18 PM
Nodscene's Avatar
I deal with a lot of Dell laptops due to work and so far haven't had any issues downgrading to xp. The X1330 was a bit of a pain but still got it done.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Portable Powerpack for laptops jgerber Mobile Computing 2 February 23, 2009 02:30 PM
Quick question regarding GPUs for laptops Cowinacape Mobile Computing 4 October 31, 2008 10:43 PM
Extreme Gaming Laptops triumph Mobile Computing 2 August 25, 2008 01:46 PM
Gaming Laptops triumph Gaming 9 August 9, 2008 07:37 PM
Stealing data from laptops magictorch Off Topic 3 June 4, 2008 10:18 PM
