Old March 22, 2009, 08:58 PM
Default Dx9- DX10
I'm running XP pro sp2 and I just got dx10 working with the help of technospot.com, my question is I had already installed all of my games when I was using DX9, not that i've upgraded to dx10 will I have to reinstall my games to take advantage of dx10 or will the game just detect it and use the new rendering?
Thanks!
Old March 22, 2009, 08:59 PM
Load up Bioshock and see if you can actually use DX10 .. doubt it.
Because this hack doesn't work.
Old March 23, 2009, 02:11 AM
What enaberif said... doubt it
If it did work then there would be threads on several sites telling how to do it
Old March 23, 2009, 07:15 AM
"Quote This..."
The problem is that most games simply detect what OS you are running and choose from there. Not what version of dx is installed.
Black belt in CAPS LOCK.
Old March 23, 2009, 08:41 AM
MpG's Avatar
MpG MpG is offline
Far Cry 2 also has a selection box for DX10, so if you have that game, you might consider checking that out too. I'd be skeptical, personally.
Old March 23, 2009, 05:23 PM
Realityshift's Avatar
Your not going to see a very big difference in visual detail by enabling dx10 right now anyhow, there is a difference but its pretty small. The problem with DX10 is the amount it can bog your FPS to get that small amount of detail. I double my fps in crysis warhead just by switching to Dx9, and I can then turn on full enthusiast settings with AA/AF and still get 35fps avg but the game looks about 5x better then trying to run dx10.
The Builders Hammer
DX10 With XP? WolfBane O/S's, Drivers & General Software 8 July 6, 2008 09:08 AM
DX10.1, the end of Dx10 cards? magictorch Video Cards 9 August 20, 2007 10:12 AM
DX10 is do-able on Windows XP Cheator Press Releases & Tech News 15 August 8, 2007 06:29 PM
CoH2 to be DX10 and SM4 Babrbarossa Rumor Mill 5 April 11, 2007 08:26 PM
DX10 for Windows XP? Babrbarossa O/S's, Drivers & General Software 4 March 17, 2007 11:37 AM
