Old March 21, 2009, 03:43 PM
Default 64 Bit Vista Ultimate and Office Ultimate 32 Bit
If you install Vista Ultimate 64 bit and then Office Ultimate 32 bit on it.
Any issues ie slowdown of main os?
I presume they run together, but does that slow down the 64 bit Vista OS as 32 bit office is running emulated (wow) or however
Thanks in Advance.
I maybe am thinking a bit to much or not enough coffee.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old March 21, 2009, 04:00 PM
Silvgearx's Avatar
it shouldn't be a problem, office ultimate should run at fine in a 64bit os. Most software that are 32bit can run in 64bit OS(32-bit compatibility mode) , usually ones with problems are device drivers.
Dont quite understand how it would slow down the OS , if it does maybe you need more rams
Maybe someone with more knowledge can help you out.
Old March 21, 2009, 04:56 PM
99% of software you run is 32bit anyways.
Old March 21, 2009, 06:18 PM
mklym's Avatar
I am running Vista Ultimate 64-bit and Office Ultimate (32-bit) on the IBM T61p that is in my sig. No problems and no perceivable performance hit.
Current Rigs
Panasonic Toughbooks
CF-18, CF-19, CF-29, CF-31, CF-52GUN
ThinkPads
X301, A31p
There is always something waiting at the end of the road, if you're not willing to see what it is, you probably shouldn't be out there in the first place.
Life's Journey is not to arrive safely at the grave in a well preserved body, but rather to skid in sideways totally worn-out shouting 'Woo Hoo! What a ride!
Old March 21, 2009, 06:49 PM
Is there even a 64-bit office?!? From what I saw, only the office-related server apps got ported to 64 bit (if that even happened).
I'm using Vista Business 64-bit and Office Professional (the plain 32-bit version) right now. Performance is fine, but then again my rig is overpowered for word processing :P Running a 32-bit app in 64-bit OS usually means a little more memory usage, but if you're borderlining the memory requirements for MS Office you should be using a 32-bit OS anyway.
Old March 22, 2009, 04:54 AM
Thanks for all the replies.
Appreciate them.
There is no 64 bit office yet
It mentions on the office blurbs that for office Ultimate that some features won't work on the 64 bit OS but none that I knew what they did anyway.
I may just wait till Windows 7 gets out.
Reason I asked is I have Vista Ultimate with the 32 and 64 bit dvds
To bad you couldn't run your key supplied on each version 32 and 64.
Although I guess vista will run without a key for a few days
Have 4 gigs of ram.
Cambridge,ON
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
vista ultimate opinion plz......... rob123 O/S's, Drivers & General Software 11 October 17, 2008 02:32 AM
FS: Windows Vista Ultimate Retail enaberif Buy/Sell & Trade 14 October 7, 2008 11:55 PM
Vista Home Premium 32 bit to Vista Ultimate 64 bit 334th_Frenchie O/S's, Drivers & General Software 4 September 9, 2008 07:45 PM
Vista Ultimate and recovery? DSNB O/S's, Drivers & General Software 2 January 6, 2008 07:23 AM
