Old March 18, 2009, 12:59 PM
Originally Posted by Eldonko View Post
I couldnt get my ATI cards to fold at all in W7 so anything is better than nothing :)
Odd lol, ive got both mine folding in the 7000 build as we speak
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old March 18, 2009, 01:09 PM
Eldonko's Avatar
Hardware Canucks Reviewer
What driver and what client? Was there anything out of the ordinary you had to do? Im using 9.2 and it just says incompatible driver.
Old March 18, 2009, 03:20 PM
8.11 i think, im pretty sure it was their beta win 7 driver that i downloaded, the file is on my old hdd though so i cant check. I remember it saying win7 in the file name though.
Case: HAF 932
Mouse: Logitech G9
Old March 18, 2009, 03:26 PM
that'd be 8.12 Win7.
Old March 19, 2009, 07:58 AM
Eldonko's Avatar
9.3 working A1 with FAH on W7!
Old March 19, 2009, 08:05 AM
Fantastic! I've been playing a bit, looking at performance differences...not seeing alot of difference though, except CCC EDID colour options are now workig on my Dell 30-inch(they weren't before).
Old March 19, 2009, 05:42 PM
anyone else notice you you arent asked to reboot after installing 9.3 on windows 7? it may just be build 7057 though, was nice not having to reboot, although i had already saved everytihng and closed it before setup finished only to find out a reboot wasnt needed
Case: HAF 932
Mouse: Logitech G9
Old March 19, 2009, 10:18 PM
hightest's Avatar
vista 64 bit//optical cable now works like windows 7 with the hdmi audio driver that comes with 9.3
i have optical cable pluged in 2 my z5500 box and directly 2 my lcd t.v and set input 2 optical on the z5500 and all works great thru the hdmi thru v card
1 less cable now i got rid of my coax cable
3d06 went up 433 pionts from 9.2//i q seems pretty darn good 2 me//my normall settings r// a.f =16//and my aa from box 2 edge-detect
ive installed win 7 7057 biuld ill test on the weekend with new drivers
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
  #19 (permalink)
Old April 7, 2009, 06:38 PM
Oversized Rooster's Avatar
Why does AMD have to be such an asswipe to release a new card (4890) but there are no drivers out there for it?!
Catalyst 9.3 does not recognize the card and therefore it neither installs CCC nor the video driver itself. I tried manual driver installation and it just doesn't recognize the 4890.
Apparently I have to use 9.4 beta drivers which also must be installed manually. What bull. You'd expect a company to support their newest top product right out of the box, no?
UPDATE 1:
I'm too lazy to deal with the manual beta 9.4 installation. I am using the Sapphire driver disk that came with my 4890. It seems Sapphire has modded the 9.3 drivers and their installer has so far detected my card.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
  #20 (permalink)
Old April 7, 2009, 07:19 PM
Pelt's Avatar
If anyone is using AMD overdrive utility have you noticed that in the GPU tab it no longer displays temp for the GPU. Or maybe it's just me, but I doubt it, I'm positive that it was there in 9.1 didn't download 9.2. I am happy with the auto overclock feature of the Catalyst driver. I know it was there before but with 9.3 it managed to find a couple extra mhz.
Catalyst 8.7 Eldonko O/S's, Drivers & General Software 41 July 30, 2008 11:43 AM
Catalyst 8.6 cadaveca O/S's, Drivers & General Software 2 June 20, 2008 09:25 AM
Catalyst 8.5 Eldonko O/S's, Drivers & General Software 10 May 30, 2008 07:45 PM
Catalyst 8.3 is out Cptn Vortex O/S's, Drivers & General Software 5 March 18, 2008 09:23 PM
Catalyst 7.2 SHaCK Press Releases & Tech News 0 February 22, 2007 07:52 AM
