Old March 6, 2009, 02:22 AM
CTA's Avatar
CTA CTA is offline
Default MSOCache from office 2007
how can i remove it in proper way?
i can't find it on the net... many msocache is based on office 2003 or older... and i tried clean disk up and listool and not work...
can i just remove it from window explorer then clean some registries from a registry cleaner?
i dont like to have it on my c:\... that junk worths almost half of a gigabyte o_O?
Old March 6, 2009, 05:39 PM
CTA's Avatar
CTA CTA is offline
o_O?
if you already installed office 2007 so... do you check your c:\ hard drive?
i want to delete it ;[
Old March 6, 2009, 06:24 PM
ipaine's Avatar
You can't delete it. Well I'm sure that you may be able to find a way, but according to Microsoft it is not meant to be removed, unlike Office 2003.
Here is some of the info that I found here. MSOcache = Local install source
The Local Install Source feature is installed so that you do not have to insert the CD during the following Setup operations:
  • The Detect and repair operation
  • The Demand install operation
  • The Maintenance mode setup operation
  • The installation of service packs and updates
Also, you cannot remove the Local Install Source feature after the installation has been completed. The Windows Cleanup Wizard does not include an option to remove this feature.
Note If you install other 2007 Office programs to different hard disk drives on the computer, an Msocache folder is created on each hard disk drive.
Hope that helps.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old March 6, 2009, 07:50 PM
CTA's Avatar
CTA CTA is offline
serious? i just dont need that junk ;\
Old March 6, 2009, 10:47 PM
ipaine's Avatar
Really though is 500MB that big of a deal? In this day and age with hard drive so large I wouldn't worry about it.
It is better than not having an up to date office in my opinion, but hey that's just me.
Of course I'm not saying don't try it either, cause if you get rid of it and things still work fine then I would get rid of it as well.
Old March 6, 2009, 11:20 PM
CTA's Avatar
CTA CTA is offline
well i split my hard in about 100gb each (3 hard drives and about 200gb for entertainment purpose...)
right now i have about 70gb space free on c:\...
i am just fussy about junks...
Old March 7, 2009, 12:01 AM
I'm still using Office XP and very happy with it, couldn't bother with M$'s updated junk to be honest, Office XP does the trick and has more features than most people will need anyways.
Old March 7, 2009, 02:01 AM
ipaine's Avatar
Don't worry I completely know what you mean. I just cleared out about 50GB of junk that was left on one of my drives from a previous install.
Old August 13, 2009, 06:45 PM
o_O?
I think this is enough .....
office window CTA O/S's, Drivers & General Software 0 October 20, 2008 12:10 AM
Office Build Infiniti New Builds 5 September 29, 2008 09:37 PM
Cheap Office PC CanadaRox New Builds 5 August 22, 2008 10:23 PM
Dad's new office PC. Ankhwatcher New Builds 29 July 17, 2008 11:59 AM
FAH #$%'s up Office? Babrbarossa O/S's, Drivers & General Software 3 November 25, 2007 08:56 PM
