Old February 21, 2009, 03:32 PM
MacJunky's Avatar
I like to actually _see_ a list of things fixed instead of being expected to update with no information about it. :)
Old February 21, 2009, 03:37 PM
That's why I put the Release Notes up in threads like this when I make 'em!!
Old February 23, 2009, 12:35 PM
Oversized Rooster's Avatar
This 9.2 is useless. It offers no performance benefit for "normal" games and it also breaks Microsoft Flight Simulator X.
It can't start anymore - it crashes with error 1033. Going back to 9.1 or 8.12 Catalyst drivers fixed everything.
Steer far and clear of this turd (9.2).
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old February 23, 2009, 12:49 PM
Yeah, I've having some issues with this set as well. I have some 2XX games here, so I was slowly going through them all...
Now i think my approach is wrong...
How do I compare? On a fresh OS install, or on an old one, as most people will be?
Old February 23, 2009, 01:43 PM
No probs with cat 9.2 on my 4670 so far.
Old February 23, 2009, 02:44 PM
bojangles's Avatar
Did you run a driver cleaning tool in safe mode before installing? Did you go through the registry to see any leftover keys were there? Just because the drivers offered no performance benefit to games doesn't mean they didn't do anything. They fixed a lot of issues that people had, like stability, incompatibilities and other errors not including gaming.
I think we're expecting too much from AMD on these driver releases. The engineers are working insanely hard when they have to release drivers every month. Nvidia, not so much. I could care less about more performance. Go out and buy another card or overclock the one you have if you don't see performance, because you won't get much more performance out of software.
This isn't directed at you Rooster. It's just a common grudge I have against people that expect each driver release to be the one they wanted each month. They can only do so much in a month. It's not just gaming that got hit also. Workstations also rely on these cards, which can affect productivity if the drivers keep crashing.
Old February 23, 2009, 03:10 PM
I'm seeing many more STABILITY/QUALITY ISSUES than with the previous set. GTA4, and The Witcher, for example, tearing in Flash Video, are three new issues that weren't there before. nVidia is able to get away with more because of the numerous software engineers posting in development houses(which is a good thing, IMHO, if you run an nV card).
AA is not working as well as it used to in GRID(if it works at all)...and I have to change display settings before I get any picture over HDMI in clone mode, although this bug was present in previous drivers as well, with the 4800-series(although 2900XT and 3870 do not have the same issues).
I don't think it's too much to expect applications that worked previously to continue to work...fixing one thing while breaking another is not acceptable in my books.
Old February 24, 2009, 12:08 PM
Jackquelegs's Avatar
9.2 Still fails with 4870 crossfirex. It won't let me enable it. So I actually had to go down to 8.11 for a working setup.
Iapetos
Zephyranthes
  #19 (permalink)
Old February 24, 2009, 08:17 PM
Exmortis's Avatar
I have cat 9.2 on my system and A ok Here. Though I have but do nto play witcher, I do however play NWN2 which is is based on and 9.2 has improved things, or it feels like it anyway. I did have some jitter in some locations, now I have none in those said locations. I run it near max settings, with just shadows at mide to high level depending on setting.
Exmortis's System
Corsair 600T White
Asus RoG Maximus V Gene
Intel i7-2600K w/Corsair H100
16GB Gskill DDR3 2400MHz
AMD R9 290X
OCZ Revo 3 240GB
OCZ Vertex 3 240GB
WD Velocirapter 600GB
LG DVD burner
LG Bluray Burner
Windows 7x64 Prem
Asus VE24/VE27/VE24
Logitech Z-5450 5.1 speakers
Corsair AX850 Gold PSU
Corsair K90 Keyboard
  #20 (permalink)
Old February 24, 2009, 08:37 PM
Hmm, I'll load up NWN2 and see if there's any difference here...
Catalyst 8.7 Eldonko O/S's, Drivers & General Software 41 July 30, 2008 11:43 AM
Catalyst 8.6 cadaveca O/S's, Drivers & General Software 2 June 20, 2008 09:25 AM
Catalyst 8.5 Eldonko O/S's, Drivers & General Software 10 May 30, 2008 07:45 PM
Catalyst 8.3 is out Cptn Vortex O/S's, Drivers & General Software 5 March 18, 2008 09:23 PM
Catalyst 7.2 SHaCK Press Releases & Tech News 0 February 22, 2007 07:52 AM
