Old February 19, 2009, 10:35 AM
Default essential tools for computer tweaking
Hi,
I just build my new computer.
Gigabyte UD3P
Q9650 + Vendetta 2
8 Gig mushkin Redline
I would like to know which software is essential for benchmarking temperature
(Idle and Fullload), getting crucial system informations, doing hdd, cpu, gpu, ram test etc...
Any essential software to be sure my computer is running good and on par with others similar setup!
Thanks
Old February 19, 2009, 10:54 AM
sswilson's Avatar
Overclocking tools of the trade
That should get you started... :)
Old February 19, 2009, 11:07 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Thick skin and if you don't have it: band aids.
Old February 19, 2009, 11:22 AM
sswilson's Avatar
Band aids are for wussies... real men use crazy glue..... :)
Old February 25, 2009, 07:06 PM
Iamcanadian7's Avatar
I was going to list a few but it looks like Wilson's list has just about everything you'd ever need
Crimp tools! Sniper Guides & How-to's 15 April 24, 2009 07:26 PM
what tools do I need to cut some holes? Shadowmeph Water Cooling 2 January 4, 2009 04:53 PM
OC Tweaking Spreadsheet misterlarry Overclocking, Tweaking and Benchmarking 0 September 3, 2008 04:44 PM
Tweaking Task Manager Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 February 6, 2008 11:13 PM
What are the dangers of tweaking latency? +extra questions! mrlie3 RAM 5 December 4, 2007 07:59 PM
