Old February 15, 2009, 07:50 PM
Default Trouble with IIS v5.1 on XP PRO
I install XP PRO, log in as Administrator, install IIS v5.1 from the XP CD. Afterward I try to access the webpage with this URL: http://localhost
It will display a screen asking for username and password..I try enter my login name but it give me this error:
You are not authorized to view this page
HTTP 401.1 - Unauthorized: Logon Failed
The 'Default Web Site' Properties as follow:
Tab 'Web Site' = IP Address: (All Unassigned), TCP Port: 80
Tab 'Directory Security', in 'Anonymous access and authentication control', checked for 'Anonymous access', Username: IUSR_<pc name>, checked for 'Allow IIS to control password'. The part for 'Basic authentication' and 'Integrated Windows authentication' is unchecked.
How can I make it so when I go the localhost webpage and it just show me the page, without asking me for username and password? Thanks!
Old February 15, 2009, 08:15 PM
Personally IIS is more of pita to learn or figure out.
Try install XAMPP which uses Apache and is 100x easier.
Old February 15, 2009, 09:36 PM
JD JD is online now
Yeah don't use IIS. Just a waste of time IMO. And probably not overly secure either.
XAMPP comes with MySQL, PHPMyAdmin, and PHP5. Also comes with FireFTP server as well. Great package to get any kind of website you want hosted.
Old February 17, 2009, 12:05 PM
Thanks for the reply..I just need IIS because installing an VoIP server software that need it...I just gonna forget about it.
Old February 17, 2009, 06:42 PM
486's Avatar
486 486 is offline
Do not listen to them, IIS is not tough and quite managable. Once you installed IIS, you have to setup your default website (your http://localhost) and set securilty on it. Simply allow for anonymous access (it will show you the account used for anonymous access). You need to create default.htm page. If you still experience any trouble accessing it, elevate permissions for the account used.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
dvd trouble part 2 t0m Storage 16 March 11, 2009 05:42 PM
annoying gta 4 trouble!!! shayan288 Gaming 13 February 23, 2009 10:27 AM
Steam trouble. Zippoh Gaming 6 December 31, 2008 07:04 PM
Icon Trouble!!! shayan288 Gaming 7 November 9, 2008 05:16 PM
PS3 wi-fi trouble ebdoradz Networking 8 December 8, 2007 05:12 PM
