<~----> How to set admin password in Vista 32bit - Hardware Canucks
Old February 8, 2009, 01:25 PM
Alwaysrun's Avatar
Default How to set admin password in Vista 32bit
Hi all. When I installed windows Vista 32bit I didn't set an Administrator password but now I'm trying to install a program that requires I put the password in for authorization to work. I'm always logged into my computer with full administrator priviledges and have no other users set up. I go straight from the windows loading screen into windows without the user login screen. How the heck do I set up a username and password now?
Sorry Vista is a pain and I'm really unfamiliar with it still so I'd really appreciate some detailed advice on how to set this up right as I really don't want to reinstall Vista from scratch...if I go that route I'd just as soon install XP again.
Old February 8, 2009, 03:16 PM
JD JD is offline
Odd that a program would want that.
Just set a password on your user account. You can do so in Control Panel\User Accounts.
That should fix the problem.
Old February 8, 2009, 03:19 PM
3.0charlie's Avatar
Same answer I gave you in your FAH thread - JD, there is a FAH app that needs a password setup.
XP? Vista? 32bit? 64bit? 7? RainMaker O/S's, Drivers & General Software 30 January 13, 2009 06:08 PM
Vista 32bit or 64bit for gaming cndian O/S's, Drivers & General Software 54 December 10, 2008 05:47 PM
WTS Vista Home Premium 32bit odis172 Buy/Sell & Trade 8 October 20, 2008 07:10 PM
x-fi elite pro and vista 32bit, anyone using? Ukonjack Audio 2 January 11, 2008 09:40 AM
Vista 32bit RAM limitations Babrbarossa RAM 22 July 16, 2007 06:31 AM
