Old January 29, 2009, 10:39 PM
hightest's Avatar
Default ati 9.1
well i installed them 2day 3d06 was 1 piont higher that 8.12 with hotfix will try games 2morrow
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
Old January 29, 2009, 10:59 PM
Chilly's Avatar
Woot, a WHOLE 1 point.
Old January 30, 2009, 12:12 AM
BrianHanna's Avatar
i did indeed try games, and the results sucked imo
this is 2 4870s at 790/1100 and 100% fan speed
8.12
3dmark06 = 20029
gta4 at high and very high settings 52.12
crysis warhead (all settings, except shaders and shadows at gamer, are enthusiast), min =21.74, avg= 54.87, max = 71.19
9.1
3dmark06= 19993
gta4 same as 8.12 = 51.37
crysis warhead same settings as 8.12 = min=21.34, avg=43.46, max= 64.97.
i uninstalled/reinstalled 9.1 several times to make sure, got the same kind of results.
disappointed, i shall be reverting back to 8.12
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old February 1, 2009, 05:44 PM
Oversized Rooster's Avatar
You're going to revert to 8.12 just because you lost between 1 and 3 FPS in some games?!
That's plain silly. You'd be missing out on all the fixes! Not all driver updates are intended to increase performance. Stability is just as important and that needs serious addressing.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old February 1, 2009, 08:29 PM
Is there a changelog anywhere? I want to see if it's worth updating.
Q6600 G0 @ 3.0GHz - P5Q-E - EVGA GTX 260 Core 216 - Corsair TX750 - Coolermaster HAF 932 - Xigmatek HDT-S1283 - Mushkin Redline 2x2gb
Old February 1, 2009, 08:59 PM
CanadaRox's Avatar
An 11FPS frop in Crysis is a pretty substantial drop, that is about a 20% drop. So if he find that the 8.12's are perfectly stable, there is no logical reason to stay with 9.1's. I've chosen older drivers over newer ones plenty of times because they ran faster.
Project: Black and White
Old February 2, 2009, 01:05 AM
MacJunky's Avatar
Just what I was about to ask.
Old February 2, 2009, 02:05 AM
Chilly's Avatar
https://a248.e.akamai.net/f/674/9206...ease_notes.pdf
Its a PDF file, so ensure you have a proper reader.
Old February 7, 2009, 06:00 AM
Dr_BenD_over's Avatar
Fallen Folder
I heard a rumour that alternate pixel center got removed...
All's well that's Haswell
Old February 7, 2009, 08:30 AM
Yeah, the option is no longer in teh control panel.
On 2900XT, I'm seeing very signifigant increases in FPS across the board in games. Perfect example is GTA4...max playable before was 1680x1050, medium details, now 1920x1080 is smooth as well(27-120FPS). Between the latest patch and the new driver, total gains are about 40%...which is very nice for such an old card.
