Old January 25, 2009, 10:11 PM
The MAX's Avatar
Default What program to monitor HDD temps?
Exactly what the topic says.
Just wondering what all of you sue to monitor HDD temps. Not something I want to have running all the time. Just want to check periodically to see how hot they get.
I have a 120mm fan running over them so I'm sure its pretty decent.
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old January 25, 2009, 10:24 PM
LCB001's Avatar
Folding Captain
Welcome th the forums
If you download this CPUID it includes a monitor for your HDD's as well as everything else...
Folding For Team 54196
Old January 25, 2009, 10:48 PM
The MAX's Avatar
thanks for the welcome, and thanks for the link!
I had CPU-Z but never knew they had something like this.
Its a great APP!
Old January 26, 2009, 08:27 AM
Jake_HT's Avatar
Speedfan monitors HDD temps also.
http://jakeht.deviantart.com/
Old January 29, 2009, 10:44 PM
ipaine's Avatar
A new one that I just ran into for hard drives is called: CrystalDiskInfo
I have it installed and like it very much. Plus it gives you all the info you need on your drives, temp, serial #, firmware, and a whole slew of SMART info.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old April 2, 2009, 10:00 AM
You can try also this solution Hard Disk Sentinel 2.81
I use it for some time and I'm very happy with it.
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
BFG Trade up program? upcoast604 Video Cards 3 October 7, 2008 02:20 PM
Best CD/MP3 Disc Burning Program TwystedMonkey Off Topic 4 March 14, 2008 05:50 PM
program Rapid-X O/S's, Drivers & General Software 8 September 3, 2007 06:13 PM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
