Old January 25, 2009, 01:17 PM
trodas's Avatar
Question How to force CHKDSK fix index on NTFS drive?
At first I made the mistake using Partition Magic v8.00 to setup a drive (2G FAT32 for OS, 184G NTFS for data). PM v8.00 is faulty and screw up the drive, mainly the NTFS partition. Usually the results are not as dramatic as I experience (mostly only windows is slow in powering off), however on VIA chipset, as this old machine use, it is hell. New files are corrupted and gone missing after reboot, etc. Bad.
(results of using PM 8.00 on VIA chipsets from Symatec page are not exaggerated at all)
In PM v8.02 or v8.05 it should be fixed, however even the v8.02 is not going to allow me to fix ANY error. It finding twice
Error 1611 bad system file name
...and about hundred times...
Error 1527 bad update sequence number
...and button FIX is still grayed out.
So I tried a workaround - used the recommended Acronis Partition Expert v8 and I downsized the D drive a bit and then get it back to former status and quess what - most of the errors and problems are gone now! No more bit table troubles with MFT, but the new file corruption and files gone missing behaviour sadly continue...
So the first thing one do is to run chkdsk, right? So I run it with parameters /x /f and it always says "Fixing error in index $I30 file 5. Checking of index finished." - that it should be translated to english... However when I run it imediatelly again, it report the very same thing!
So the error is NOT fixed.
So I get the idea that I just find the file no. 5 using MFT table and kill it. Using DiskEdit utility (from Win2k SP4 CD by M$ itself, grab it there: RapidShare: Easy Filehosting ) I opened the NTFS D drive and - sadly instead of the path and file I saw only couple of empty boxes... I can check other files fine, so, what now? It is a system file or hidden something then...?
I tried threat that as it is a deleted file fragment or something like that. I tried the Recuva utility from Sysinternals, because it can safely erase the deleted files, based on the MFT infos... If you did not know, well, then MFT store and keep information about every files you ever had on your HDD, so... (MFT on my drive have 57MB currently) Recuva found like 16k of deleted files, so I check them all and say - delete them right away!
But things went wrong, as some of the files are "resident" in the MFT table, so, they are not deleted. Also Recuva cannot delete the infos MFT keep about files long time gone from HDD. So I tried the recovering utility Restoration v3.2.13, because it know not only erase files, but also erase the infos about them in MFT! Then in Recuva you see only 16k of empty lost file infos, hehe.
But that did not help me either.
Then I tried Winhex v15.1, witch offer fantastic things, and among others - erasing the unnecessary MFT infos. However it again only erase the missing files infos, not remove them from MFT - it probably did not know how to rebuild the MFT then... So, no improve in the chkdsk error and HDD behaviour done...
Hence - anyone have any ideas how to fix this index problem? Chkdsk /x /d /r D: run way too long and at the end, no change at all.
Also I tried chkdsk from the Windows repair console, however no difference. It says that he find something, but then again - it did not fix it. And only report that find and fixed errors the first time I run it. Each next run it make there pauses (hence 3 errors, I presume) but not report them anymore!
Much less to fix them...
So when I get back in win, it way agaion like that:
Program CHKDSK ověřuje soubory (fáze 1 z 3)...
Ověření souboru dokončeno.
Program CHKDSK ověřuje rejstříky (fáze 2 z 3)...
Probíhá oprava chyby v rejstříku $I30 souboru 5.
Ověření rejstříku dokončeno.
Program CHKDSK ověřuje popisovače zabezpečení (fáze 3 z 3)...
Ověření popisovače zabezpečení bylo dokončeno.
193253884 kB místa na disku celkem.
190638064 kB v 37513 souborech uživatele.
14644 kB v 1583 rejstřících.
0 kB v chybných sektorech.
78740 kB používá systém.
16384 kB zabírá soubor s protokolem.
2522436 kB na disku je volných.
4096 bajtů v každé alokační jednotce
48313471 alokačních jednotek na disku celkem.
630609 volných alokačních jednotek
So, anyone get any idea about chkdsk replacement that works? Or thanks to PM, I have to backup my entire drive on DVDs and format it and then copy all the data back or what?!
It is VERY annoying to lose data in new files and I of course run diagnostic tests on the drive and then SpinRite v6 and the drive is perfectly okay. A not so old 200G Seagate PATA one :)
PM reporting WAY less errors after the trick I made with Acronis Partition Expert, but still... they are there. Help?
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old January 25, 2009, 01:46 PM
put in windows cd
in cmd window type sfc /scannow
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old January 25, 2009, 02:04 PM
Originally Posted by jay51 View Post
put in windows cd
No.
You right click on the drive and choose tools and select Scandisk.
If its your OS drive reboot and it'll do it.
Old January 25, 2009, 02:16 PM
Originally Posted by enaberif View Post
No.
whats the scannow do?
its purpose
replace sys files?
thanks
Old January 25, 2009, 02:22 PM
its purpose
replace sys files?
thanks
scannow simply scans the \Windows directory for any changed or corrupted files and replaces them.
If the hdd is so broken that scandisk cannot run or do its job properly then you need to run something different like HDAT2 which can be found on the UBCD for dos.
It'll scan the hdd drive and report any bad blocks or sectors with the drive.
Old January 25, 2009, 03:17 PM
trodas's Avatar
sfc will mainly try restore WFP and revert my cool changes to windows :)
Anyway, I "scandisk" by right click/tools/check drive just run the same chkdsk utility I run from commandline. No difference. No difference in results.
G-Force 6800 GT Shredder Video Cards 6 September 14, 2008 06:01 AM
Fat Partition to NTFS Boot Partition PaxeSalute O/S's, Drivers & General Software 1 May 2, 2008 01:28 PM
Foxconn Intel P45 Quantum Force 'Avenger' Exposed Hardware Canucks CPU's and Motherboards 0 May 2, 2008 10:11 AM
Ge Force 8600gts or radeon x1950pro optimus_prime Video Cards 11 September 5, 2007 01:06 AM
Comment Thread for Tagan 2-Force II 600W PSU Review SKYMTL Power Supplies 2 August 15, 2007 01:50 AM
