Old January 21, 2009, 12:54 AM
DRYJESUS's Avatar
Restricted Poster
Default Boot Problem
Hi,
I have been using Vista 64 bit, but I wanted to try Windows 7 Beta. So I installed the Beta 64 Bit on a different partition, just to try first, and I loved it! My partitions looked like this:
100GB: Vista
100GB: Windows 7
300GB: Data
I was ready to use this as my main OS. So I deleted my Windows Vista Partition after backing up, and now I can't boot into Windows 7. Now my partitions look like this:
100GB: Windows 7
400GB: Data
This obviously has something to do with deleting my Vista partition as it was working before. If anyone could help me ASAP, that would be great, as I need my computer for schoolwork.
Edit: Please don't rant to me about why I'm using the beta as my main OS. I don't know, I'm just like that.
Old January 21, 2009, 02:01 AM
Infiniti's Avatar
If you burned the beta to a disc, it might be like Vista where you can load it up and repair the MBR. I'm not sure, but I guess it's worth a shot.
Old January 21, 2009, 05:08 PM
DRYJESUS's Avatar
Restricted Poster
nope, i've already tried repairing, but thanks for the suggestion!
Old January 21, 2009, 05:12 PM
sswilson's Avatar
Have you tried re-installing Vista 64bit? I'd guess that your boot manager was on the partition that got deleted... maybe if you put vista back on it'll recognise windows 7 as another version of itself and create a dual boot?
Old January 21, 2009, 05:13 PM
Load the recovery console from the disk. (Under repair if it's like Vista.) and try running the commands bootrec \fixmbr and bootrec \fixboot
The automatic repair didn't work properly if it's like vista.
Old January 21, 2009, 05:39 PM
DRYJESUS's Avatar
Restricted Poster
okay, i'll try that right now
Old January 21, 2009, 05:43 PM
DRYJESUS's Avatar
Restricted Poster
After the command bootrec \fixmbr, it was successful, but after bootrec /fixboot,
it gave me "Element not found"
Old January 21, 2009, 05:58 PM
Shadowmeph's Avatar
try this if you don't have a Vista boot disk Windows Vista Recovery Disc Download — The NeoSmart Files
Old January 21, 2009, 06:05 PM
DRYJESUS's Avatar
Restricted Poster
okay, i'm downloading right now, 10 minutes to go
edit: what does this do? it just looks like a normal vista disk
My Boot settings (Bootsect.bak/Boot directory) installed to another HDD? chouchou Troubleshooting 7 December 21, 2008 08:46 PM
won't boot up Jhayman Troubleshooting 0 December 6, 2007 11:41 AM
cant boot into XP magictorch Troubleshooting 2 November 17, 2007 03:42 PM
Post or Boot? Preemptive RAM problem magictorch Troubleshooting 2 November 11, 2007 08:30 PM
No way to boot sciwhiz Troubleshooting 13 October 27, 2007 05:41 PM
