-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Restoring files? (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/13858-restoring-files.html)
Phobia January 15, 2009 08:02 AM
Restoring files?
Hi all. I need help! my dad is very computer challenged, and today he some how wrote over his 2008 work file. It contains all of his invoices and everything. Its in quattro pro, which is a spreadsheet. And he never backed it up. Is there anyway to see or get the old part back? Its going to take him days to redo.
Chilly January 15, 2009 08:20 AM
Sorry to be the bearer of bad news, but.... If he wrote OVER it, chances are there's nothing you can do.
Phobia January 15, 2009 08:47 AM
Bah. I thought so, but I was hoping
chrisk January 15, 2009 09:22 AM
I have never actually tried it but if he has Vista you can try possibly the shadow copy thingy (right click on the file and I believe it says "Previous Versions" there somewhere. Something to consider.
If he had simply deleted it then there are various file recovery programs available to try...I have used Bad Copy Pro, and "Recover My Files" to successfully fix corrupted files and to retrieve deleted files.
NyteOwl January 15, 2009 05:21 PM
I haven't used Quattro in a VERY long time but as I recall it made it's own backup's automatically as you worked so that there was always the last copy available for restore. I for get if they used a ~ in the extension on bkp/bak now. As I said it was quite some tije ago but you might check in both the working directory adn Quattro's own directories and see if a backup might be there.
bushwhacker January 16, 2009 08:50 AM
In Corel QuattroPro:
  • Open QuattroPro, and then click on “Edit” and then “Preferences”. Click on the “File Options” tab. Check that “Timed Document Backup Every” has a check mark in the box in front of it, and a time value in the “minutes” window. If you want QuattroPro to use a different default directory, you can type the full path in the “Directory” window, however, QuattroPro uses the last-used directory as the default directory, so your preference may not stick.
check this to see what preferences your Dad has set and where the backups may be
Cranky January 19, 2009 01:14 PM
If you can't find them in the default backup file, there are data recovery services, that is, if your dad's information is important enough to warrant the cost to have it recovered.
