Old January 13, 2009, 12:24 PM
Skyllz's Avatar
Default Easiest way to image a drive.
I'm looking for a fool proof way to re-image a drive.
Something simple that the image would all fit on a 16gb USB key and you can boot from it to recover style of simple.
It's for my dad that... errr... browses websites and clicks on stuff sometimes he may not be supposed to. That's his story and he's sticking to it
I have a HD I keep my images on and carry to his place to re-image it once in a whole when it's fubared but i'd like to have him do it himself from now on. This is why I need it simple.
Thanks.
Is smoke supposed to come out of there?
Old January 13, 2009, 07:13 PM
Lots of good choices - If you are running Vista Ultimate , the built-in Windows Backup Image is fantastic. Others you can try - Acronis Disk Image or Norton Ghost. The size of the image will depend on the size of the disk that you are trying to image.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old January 20, 2009, 03:16 AM
i've used norton ghost in the past, and its great
Old January 20, 2009, 03:22 AM
Eagle Eye's Avatar
Acronis disk image, life saver.
Old January 20, 2009, 02:29 PM
sam101p5's Avatar
+1 for Acronis --- I actually created a bootable image of my XP drive with that program a couple years ago so I could keep my main drive safe after a 'family' tinkering weekend. The only program that failed to work on the new image was Norton system works/anti-virus, but I didn't care because I knew my relative was going to wipe it out anyway while I was sleeping -- and he did.
Old January 20, 2009, 02:39 PM
DK2 DK2 is offline
I don't think windows backup has compression even the vista version.
Acronis is very good.
Old January 20, 2009, 02:41 PM
+2 for Acronis...
-1 for Ghost
Intel C2D E8400 (SLB9J - Q829A202) @ 8.5x533 1.3625vcore
Interl C2Q Q6600 (SLACR - L823B214) @ 9x400 1.3265vcore
Asus P5Q Pro
Corsair TWIN2X4096-8500C5D
TRUE 120 + 2x Scythe SFF21F
ATI Radeon HD 4850 @ 775/1200
Dell S2409W 24" 1080p Monitor
Old January 20, 2009, 03:18 PM
b1lk1's Avatar
Ghost 14.0 has worked flawlessly for me.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
No image on screen SuperFriedFish Troubleshooting 9 September 7, 2008 10:37 AM
XP Pro on New Rig - Install or Image? misterlarry O/S's, Drivers & General Software 3 April 16, 2008 10:18 PM
Bootable image... omgwtf O/S's, Drivers & General Software 2 June 10, 2007 09:00 AM
