Old December 28, 2008, 03:59 PM
CORE's Avatar
TechWiki Moderator
Default OS Stability Question
Is windows vista home premium 64 stable? Its because my system always freeze on windows vista home premium 64 bit and when i use xp im stable enough. Thanks
Old December 28, 2008, 04:19 PM
Why do you ask while you already answered you own question!?
I’ll use Windows Vista Home Premium 64 bit and it works fine for me. I have not been noticing any freeze or any kind of lag.
Please post u PC, maybe it will help to solve you problem…
Old December 28, 2008, 08:31 PM
Depends on a lot of variables.
Do you have 4gb of ram? Do you have the latest service pack installed?
Have you checked your system for stability?
Old December 29, 2008, 10:08 AM
Personally ive never had Vista x64 freeze once, im using ultimate though but there shouldnt be any difference.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old December 31, 2008, 07:01 AM
You'd need to list the rest of your system specs. Could be a conflict, especially if you're running older drivers. Vista x64 drivers were not very stable in many cases to begin with, though most, if not all, of these issues have been ironed out now. I'd make certain you're running recent drivers. If XP runs without a hitch a hardware problem sounds unlikely.
Case: Antec 1200.
CPU: Intel Core 2 Quad Q9550 @ 3.5GHz.
Motherboard: Asus P5Q Pro.
RAM: 4GB Corsair Dominator Twin2X PC2-8500.
Graphics: Xpertvision Radeon HD4870 1GB.
Sound: Auzentech X-Fi Prelude 7.1.
HDD: Samsung Spinpoint F1 750GB.
PSU: PCP&C Silencer Quad 750w.
OS: Vista Home Premium 64bit OEM.
Old January 1, 2009, 03:10 PM
no_pulse's Avatar
I'm running Vista x64 Ultimate and it has only crashed once since I've been using it. And I have been using it for months and months. Personally, I'm glad I made the switch from Xp to Vista. I'm very happy with Vista :)
Old January 4, 2009, 07:53 AM
Lightbulb
Yes Vista 64 bit is for the most part.
Is your XP 64 bit?
Or 32 bit?
Another issue causing the problem most likely?
For Vista you must have the proper drivers
Did you run the Vista checker from MS for your machine
Cambridge,ON
MSI Z77 M Power/Bios17.7
i5 3570k@4.5ghz
Mushkin #997007
Noctua NH-D14
EVGA GTX460
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
Old January 4, 2009, 03:06 PM
belgolas's Avatar
Make sure you have the latest drivers.
Make sure you don't have any spyware/viruses that could cause instability
I have found some wireless adapters are the cause to some of my instability I have had before. That is why I have gone through about 6 so far.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old January 4, 2009, 07:19 PM
Shadowmeph's Avatar
there are some reasons why I personally don't Like any Vista which are you have to have a fair amount of Ram and you don't Get your top Download speed ( its capped).that being Said between 32 bit and 64 bit Vista I have had allot more problems ( stability issues) with 32 bit over the 64bit you have to think of Vista Like the Old Windows ME its a go between experimental model well at least this is the way I see Vista . This is why the only Windows based OS I use is 64bit XP all of my other OS are 5 Linux Distro's and 1 FreeBSD but
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old January 4, 2009, 07:49 PM
belgolas's Avatar
Vista doesn't cap your download speed. Your crappy internet provider does. You ever told you that was on crack.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Q6600 OC with Water stability issues gazdag6 Overclocking, Tweaking and Benchmarking 7 September 11, 2008 07:36 AM
Stability problem on my e6600 Gooses Overclocking, Tweaking and Benchmarking 9 September 9, 2008 11:07 PM
ATI/AMD driver stability cvmocanu Video Cards 4 August 13, 2008 03:20 PM
4850 Stability Oversized Rooster Video Cards 42 July 30, 2008 08:30 AM
Stability testing GPU O/C biff Video Cards 9 April 7, 2008 05:29 PM
