Originally Posted by Mr. Friendly I don't understand your numbers jd. 3 OS over 4 screen. my primary OS will utilize 2 screens while the other two instances will have 1 screen each. if I have 3.5GB of RAM, that should give me 1.5GB for the primary OS and 1GB for each of the VM OS' running. I would just need to install another video adapter so I could display all 4 monitors.
with quad core I could still multi-task easily on the primary OS with 2 cores while using 1 core for the other 2 in VM.
another issue would be I have zero experience with running anything in VM...I'll have to give it a shot at home on my laptop. what free VM engine is the best and/or easiest to use? |
Running a VM is exactly like running any OS; The only difference is that it relies on resources from the host.
Another thing that can get tricky sometimes is networking for shares between the host and VM.
It also depends on how demanding these virtual machines are going to be as they may not need a lot of ram.
