Old December 17, 2008, 12:42 PM
lcdguy's Avatar
Originally Posted by enaberif View Post
Don't bother asking this question as you'll never get a precise answer from anyone and will always have a heated debate.
Myself I don't see any reason to run Vista as it doesn't give you any benefit over Windows XP despite what others will say and no if you only have 4gb of ram you don't need a 64bit OS a 32bit OS will work just fine.
IMHO Superfetch and DX10 is a marketing gimmick and if your computer is fast enough whether you have superfetch or not things will load fast.
i would agree with this. Basically if you plan on have 3gb or less of ram then installxp if you want 4+GB of ram go with 64 bit vista.
Or dual boot :D
Old December 17, 2008, 12:53 PM
Oh, no doubt that DX10 and "Games for Windows" is a marketing gimmick, they need something to bring people to Vista by saying all these games will only work with Vista. Hell, people got Halo 2 to work with XP, and people have been working on wrappers to get DX10 to work in XP. Its a shame MS doesn't want to release a XP version but I guess whatever it takes to get sales of a slumping product up.
XP or Vista, both are generally the same...if you dont care about "Games for Windows" titles. If you do, and you're really wanting to play these...might as well buy Vista
CM690 - Asus P5Q-E - Intel E8400(E0) @ 3.6 - OCZ GameXStream 700W - Swiftech Apogee GT (Bowed) - 2x2GB Mushkin Redline PC-8000 - EVGA GTX 260 - Samsung 226BW
Old December 17, 2008, 01:01 PM
JD JD is offline
It's okay enaberif, we all know how much you dislike Vista (or at least the regulars on here do).
Though why use a 32bit OS and loose about 512MB (or more) of RAM? Seems wasteful to me.
Old December 17, 2008, 01:15 PM
Because your not going to notice that loss; simple.
90% of applications are written in 32bit code anyways so even if you DO run a 64bit OS those programs are still native 32bit programs that will never be able to use more than the allocated 2.5gb of ram given.
So why bother with 64bit if you only have 4gb of ram? You don't.
Now if you have 6, 8, 12 perhaps or even a video card with large memory demands (tho this hasn't been 100% proven) ok.
Old December 17, 2008, 03:28 PM
MacJunky's Avatar
Unless of course you are running multiple applications that each gobble RAM thatis.
Old December 17, 2008, 03:31 PM
b1lk1's Avatar
If you are buying an OS, then I would get Vista. If you already have a legit copy of XP then there is no need to get Vista.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old December 17, 2008, 03:33 PM
Yes of course but it still will only eat up to 2.5gb of ram and can't go any higher :P
And if people are running that memory hungry of applications then yes by all means go 64bit but at this point in time VERY few apps do that.
Old December 17, 2008, 03:48 PM
Nodscene's Avatar
Actually I believe you need Nero 8 for Vista. I know that 7.5.1.1 will not install on Vista but I'm not sure of when it became compatible, so 7.6 may work or not.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
  #19 (permalink)
Old December 17, 2008, 03:52 PM
Nero is garbage. So many alternatives out there that do much better and aren't as bloated.
  #20 (permalink)
Old December 17, 2008, 03:57 PM
sswilson's Avatar
I actually use Nero, but it's mostly due to the fact it was free with a burner, and it will burn to my lightscribe disks. I've yet to find a freeware / opensource app that will do any more than basic text on a lightscribe disk.
Vista 32bit or 64bit for gaming cndian O/S's, Drivers & General Software 54 December 10, 2008 06:47 PM
x-fi elite pro and vista 32bit, anyone using? Ukonjack Audio 2 January 11, 2008 10:40 AM
32bit Vs 64bit XP enzeo O/S's, Drivers & General Software 6 September 28, 2007 01:53 PM
Vista 32bit RAM limitations Babrbarossa RAM 22 July 16, 2007 06:31 AM
Vista 64bit vs. XP 32bit 4GB RAM bench comparo Eldonko O/S's, Drivers & General Software 13 May 14, 2007 01:09 PM
