Old December 14, 2008, 09:57 AM
dadzilla's Avatar
Default Noobi Stuff: how to find system info
Well, I'm kind of a noobi, but two useful things I found out are "dxdiag" and "msinfo32". Type these into the "start search" in vista or the "run" in xp, and you get info about your system. Anybody got a favorite one to share?
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
Old December 14, 2008, 10:02 AM
CTA's Avatar
CTA CTA is offline
type "system information" and "device manager" in vista then you will find all information you need...
Old December 14, 2008, 10:24 AM
JD JD is offline
Running a program like Everest tells you everything you'd want to know including temperatures and fan speeds.
Noobi OC question dadzilla Overclocking, Tweaking and Benchmarking 14 December 22, 2008 09:06 AM
Where to find this speaker NyteOwl Audio 4 August 11, 2008 01:58 PM
Where can I find C-Strip ... Synth Cases 5 December 3, 2007 09:25 PM
Help me find a NB/SB block moditir Water Cooling 3 July 20, 2007 09:06 PM
What did you find under the tree?????? sswilson Off Topic 7 December 26, 2006 05:27 AM
