Old December 12, 2008, 11:12 PM
CTA's Avatar
CTA CTA is offline
Default ntune = crashing
when i open ntune monitor and it crashes...
but when i open CP, stability test, and preformance and they are directing to CP...
so why does it crash? and i also want to change sli mode option for 9800gx2...
Old December 13, 2008, 12:41 AM
rjbarker's Avatar
Get rid of Ntune..delete it...remove it....disable it....take a baseball to it.... Really, its a terrible Program, nVidia should be ashamed, folks have nothing but problems with it! Between Precision and nVidia Control Panel you shold be able to take care of averything.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old December 13, 2008, 12:51 AM
CTA's Avatar
CTA CTA is offline
well... i heard that ntune had a sli mode feature... so i want to disable my sli mode in 9800gx2 because i dont play the game yet... ;p
Old December 13, 2008, 01:15 AM
rjbarker's Avatar
Are you talking about Ntune or your nVidia Control Panel?? You can disable SLI in your nVidia Control Panel...nTune is a different Program altogether.
MARK 11: 32.530
Old December 13, 2008, 01:24 AM
Linus's Avatar
nTune is garbage. I've never seen it work correctly.
Why would you want to disable SLI mode because you don't play the game yet? What game?
CTA's Avatar
CTA CTA is offline
i see... i am going to uninstall it now... but i can't find that option in CP...
i used 178.13
edit: enable sli mode to play the movie, and other tv show is overkill... 75% of time to watch and 25% to surf the internet...
Old December 13, 2008, 02:08 AM
i used 178.13
AFAIK it only uses SLI when its needed.
Old December 13, 2008, 11:13 AM
JD JD is offline
So why did you bother getting a 9800GX2 then? Seems kind of silly...
Old December 13, 2008, 11:28 AM
CTA's Avatar
CTA CTA is offline
i see..
i got 9800gx2 for very good deal... 260cdn compare to 260 ( non 216) for 320 and gtx280 400+
anyhow... this is not game seasons yet... on next month or so i will start my game seasons...
clocking and crashing and gaming and folding and crashing vinister Overclocking, Tweaking and Benchmarking 5 June 30, 2008 11:22 AM
Ram Crashing System canadianicon25 Troubleshooting 14 June 4, 2008 01:47 PM
BF2 crashing,, curtispan Troubleshooting 8 January 2, 2008 04:51 AM
Nvida nTune BALISTX Overclocking, Tweaking and Benchmarking 7 August 18, 2007 10:42 AM
New NTune Released Today Babrbarossa Video Cards 3 January 17, 2007 12:36 PM
