  #21 (permalink)
Old January 1, 2009, 12:51 AM
MpG's Avatar
MpG MpG is offline
Aside from the usual range of common hand and power tools:
Crystalfontz 633 LCD display, for use with DS18B20 digital temp sensors.
Head-mounted flashlight (for hands-free operation).
Pin crimper
  #22 (permalink)
Old January 1, 2009, 10:45 AM
3.0charlie's Avatar
Originally Posted by 3 of 7 View Post
On the upside I haven't had a smoke in 3 days.
Keep it up, I quit just like that 1.5 years ago, after smoking for 20+ years.
Hydro-Quebec is salivating...
  #23 (permalink)
Old January 1, 2009, 11:24 AM
3 of 7's Avatar
I intend to, been a week now and I'll be just fine I think.
  #24 (permalink)
Old January 1, 2009, 11:26 AM
3.0charlie's Avatar
It's worth it.
  #25 (permalink)
Old January 1, 2009, 12:56 PM
dragoonxx's Avatar
current inventory of mine
Dremel
Soldering iron and solder
Ratcheting Screwdriver
CFL Portable Lightbulb (plugs into a light socket, great fill lighting)
Assorted Clamps
Heat gun
Heat shrink and sleeving
Multi-meter
I.R Gun
Zip ties
Cable tie anchors
side snips
  #26 (permalink)
Old January 1, 2009, 03:51 PM
vinister's Avatar
I also own an orange snap-on ratcheting screwdriver ;)
except mine is a T-handle... they are the best
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
  #27 (permalink)
Old January 2, 2009, 06:55 AM
Snafu's Avatar
A power switch from an older computer. The kind when you push the button it stays on or off (not like today's momentary switches). I take the jumper off the CMOS reset header and plug it in. Let's me reset the bios without having to move the jumper back and forth when tweaking the bios.
I also made a test bench. I can pre-assemble, test and tweak the hardware before putting them into the case.
Newest system: Intel E8400, Gigabyte EP35-DS3P, OCZ PC2-9200 Reapers, Seagate 3GB/s HDD, etc.
Others are kicking around the house.
  #28 (permalink)
Old January 2, 2009, 02:43 PM
I had like 4 Snapon Phillips screwdrivers, and I lost them ALL!
Now I have some cheapie brand.
Oh and a electric screwdriver. Those kick
Nice bench snafu.
I ended up buying a pair of Highspeed PC Tech Benches.
GREAT for testing a computer outside a case.
As for other tools:
-Zip ties (GO dealextreme!)
-4 pack of ISO
-Needlenose pliers for when you drop a screw in a stupid place
-KVM switch
-http://thermoworks.com/products/ir/irpro.html
Multimeter is nice too. Although I keep losing mine.
  #29 (permalink)
Old January 2, 2009, 03:52 PM
Pin crimper
W0t.. Sweet ..
I also have a tube of arctic silver 5 and arctic clean (2 bottles).. also have gloves just in case.. A set of LN Keys to be on the safe side also..
Overclocking tools of the trade 3.0charlie Overclocking, Tweaking and Benchmarking 58 January 12, 2014 12:20 PM
Follow Freeman lcdguy Gaming 2 December 3, 2008 09:54 AM
Component Boxes/Tools arekieh Off Topic 10 November 16, 2008 06:02 PM
Overclocking/Benchmark Tools CasheKicker Overclocking, Tweaking and Benchmarking 6 March 20, 2008 12:35 PM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
