Old December 7, 2008, 09:26 PM
Trial Member
Default How do you create a raw soud file?
I have a question lately I have been editing stronghold crusader and the music is in a raw file format how would I convert a sound file to this format please help thanks.
Old December 11, 2008, 11:05 AM
S_G's Avatar
S_G S_G is offline
There is no such thing as a "RAW" audio format. It's a misnomer, since WAV files are technically "raw", meaning uncompressed. So, I would assume that RAW contains uncompressed PCM, like WAV, but in reality it could be anything.
HTPC: MSI Z77A-G43 + [email protected] + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
