Old November 28, 2008, 02:41 PM
Shadowmeph's Avatar
Default AMD Fusion for Gaming does this actually work?
AMD Fusion for Gaming I just heard about this and I am not sure if it works or not does anyone know?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 28, 2008, 02:59 PM
vinister's Avatar
I use it and rather like it.
It only works with spider platform systems aka 790x.
It loads up my CCC overclock profile, and can load your overdrive profile (I dont use it tho), and cuts out a large list of vista services. It really reduces the ram footprint of the OS by a huge chunk, and effectively speeds up your system a bit. It also enables a couple of 790x tricks, I'm not exactly sure what.
I don't know what the fps gains would be, if any, but it's more just to provide a quick button to kill all the 'crap' processes that are always running.
The only downside is that it can't always bring things back perfectly when you turn it off. Sometimes the aero interface comes back, sometimes not. Sometimes a reboot is necessary afterwards to bring everything back to normal. I tend to use it mostly when benching.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
