Old November 20, 2008, 11:12 PM
CTA's Avatar
CTA CTA is offline
Default strange browser freeze
i have no idea why IE7 freeze then close/restart... not only ie7 but ff and opera too...
i try to scan everything and can't find source...
what is really problem? maybe bad registers?
i use vista64
Old November 20, 2008, 11:21 PM
What do you mean freeze? When does it freeze? How does it freeze?
Old November 21, 2008, 12:35 AM
CTA's Avatar
CTA CTA is offline
out of the blue... during i surf any sites... it freezes then closes down... sometime it will ask me to restart the browser... i did try to click something that can find a solution (diagnose prompt like) and it not helps...
Old November 21, 2008, 12:38 AM
you may want to check your system for instability.
Old November 21, 2008, 12:49 AM
CTA's Avatar
CTA CTA is offline
like?
mine is not overclocking... i just rollback to stock...
Old November 21, 2008, 01:03 AM
fire up IE in Safe mode and see if it does the same thing.
Old November 21, 2008, 01:18 AM
CTA's Avatar
CTA CTA is offline
ok i will check it um 20 hours later... torrent reason.
i will let you know about safe-mode...
