Old November 17, 2008, 07:02 AM
Dr_BenD_over's Avatar
Default Teamspeak - Can't connect anymore!?
This is weird. I can no longer connect to my TS server via the real world IP. Other's can, but I can't connect to my account or the general account if I use the external IP. If I use the internal IP it will work, but it's odd that it just started doing this when I've used the external IP for YEARS. My TS server is still presently on my gaming machine as I haven't had the time to set it up and test it on my Atom. The correct ports are forwarded to the correct local IP. I though maybe it had something to do with port 80 now being forwarded to my Atom, but it worked last weekend. Any thoughts? I've reset and rebooted the router, used the other LAN port on my PC. Removed last weeks patches and actually wnet back to a system restore point on the PC from when it worked.
If it's stupid and it works, it isn't stupid.
Old November 21, 2008, 02:00 PM
OK really confused now. I've got it up and running on the Atom, but I still can't connect via the real work IP anymore
Old December 3, 2008, 10:42 PM
Your tcp Query port is forwarded aswell? Default is 51234
This url will give instruction on how to determine your query port.
TeamSpeak TCP Query Port Finder - TSViewer.com
This url will test your server's accessibility from outside your network.
Manual TeamSpeak Server Scan - TSViewer.com
Hope it helps, I have a couple of those running here, 1 per ip address.
Code:
Old December 4, 2008, 03:21 PM
It shows up and everything, I can even admin the server via the real world IP, but it won't connect with the client.
Not PC related, I tried my Vista boot and my craptop, same thing, so router (again) or ISP (I have been having issues with Hamachi too)
Can't connect from work using Eastlink, but that may be the firewall at work, but I can connect from the craptop using dial-up from Aliant.
Old December 5, 2008, 08:21 AM
I assume your windows firewall, Norton firewall both have TS Server and TS client ports and permissions set to go? Port 80 is sometimes shut down by isp's, in any case it wont affect your TeamSpeak.
Code:
