  #41 (permalink)
Old July 19, 2008, 03:53 PM
Digitaldemon's Avatar
Ok I noted Ifranview is not here...
IrfanView is a very fast, small, compact and innovative FREEWARE (for non-commercial use) graphic viewer for Windows 9x/ME/NT/2000/XP/2003/Vista.
  #42 (permalink)
Old July 19, 2008, 04:04 PM
Jack Rabbit's Avatar
I know Ifranview is very popular and lots of people like it but I have tried it several times and I just can not wrap my head around the UI. Here is another free alternative:
Free graphic and photo viewer - XnView - GRAPHIC VIEWER
- James Graham
  #43 (permalink)
Old July 19, 2008, 07:07 PM
Okay for just about anything you ever wanted to know about your system info, hardware etc, I have been using this for years:
|MG| EVEREST Free Edition 2.20
CPU-z can provide info on your CPU and RAM specs:
|MG| CPU-Z 1.46
Ever wondered what all the processors running are, well this app extends the task manager significantly and allows right click "googling" of any background process:
|MG| Process Explorer 11.20
Most have heard off and used memtest86+ but here is a Windows based memory tester:
MemTest: RAM reliability tester for Windows
A temp/volt monitoring app that generates min/avg/max for any bench runs:
|MG| HWMonitor 1.1.0
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
  #44 (permalink)
Old August 25, 2008, 04:34 PM
Dwayne's Avatar
I didn't notice any backup software! You are a brave lot of OC'ers out there
AceBackup: The free Backup Software
Works very well. I have not tried any scheduling with it but I set up a back up and then run it manual and it does an incremental of new files only.
Recommended!
Dwayne's Rig - eVGA x58 SLI LE : i7 920 @ 3.4 GHz : Mushkin 18GB mixed Silverline and Blackline : Corsair HX850W PSU : Corsair H100 : Corsair Obsidian 650D : eVGA GeForce GTX 580 : Creative X-Fi Extreme Music
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : Sapphire HD 6670 : Nmedia HTPC 1000B : Kingston 60 GB SSD Boot
Netbook - Asus eee
Tablet - Asus eee Transformer
Wife's Rig - Toshiba Laptop!
  #45 (permalink)
Old August 25, 2008, 04:44 PM
sswilson's Avatar
Recommended!
Heh....
Not brave, I just don't leave anything on my computer I can't afford to lose. Only takes a couple of hours to reload everything if required. :)
  #46 (permalink)
Old August 25, 2008, 06:14 PM
Supergrover's Avatar
Originally Posted by sswilson View Post
Heh....
Same, I use multiple drives for storage now, the wifes backs-up useing Nero thru the network to a storage drive.
Plus I format about 4 times a year so whats the point, I want clean installs.
R.I.P.
  #47 (permalink)
Old August 30, 2008, 06:57 AM
Shadowed's Avatar
My hard drive is soooo big, it starts beeping when it backs up...
  #48 (permalink)
Old September 4, 2008, 03:55 AM
KnSKranky's Avatar
Here's another I didn't see posted here.
Avast! Antivirus Home Edition(free), fully functional with 6 resident scanners. I've been using it for years and prefer it over AVG.
FREE avast! antivirus 4.x Home Edition, anti-spyware & anti-rootkit for Windows You do have to renew your license every 14 months but its still free.
i5 3350P @ 3.1ghz
8192mb DDR3 Corsair Vengeance
Gigabyte GTX 660 2gb
Windows 8 Standard
Gigabyte GA-B75M-HD3
1TB SATA III
Realtek Onboard
NZXT Phantom 410 Gaming Case
Corsair 500w
  #49 (permalink)
Old September 7, 2008, 08:07 AM
sswilson's Avatar
It's been years (maybe even a decade) since I used Arachnophila for coding HTML, and I haven't tried this version, but it was a decent freeware app back in the day so it deserves a mention......
* Arachnophilia
For those who've used it in the past, apparently it's now a java app, so it will work across all platforms.
  #50 (permalink)
Old September 14, 2008, 02:34 PM
sswilson's Avatar
Been a while since I needed to use it, but if you've got a friend/relative who either insists on purchasing a big-box build, or just has an itchy "accept" mouse button PC Decrapifier can come in quite handy......
Welcome | The PC Decrapifier
