-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   vista --> XP gateway with aircard (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/11637-vista-xp-gateway-aircard.html)
raprat November 9, 2008 12:25 AM
Apologies if this should be in the networking thread instead.
I've got a sierra wireless aircard connected via USB to a laptop running XP. The laptop is connected via LAN to a DLink wireless router. I've got another laptop running Vista premium that I've managed to network to the XP machine, but I can't for the life of me establish a connection to the internet
On the XP machine:
- All 3 options under internet connection sharing are checked
- Router is configured with IP addy 192.168.0.2
- laptop is IP 192.168.0.1
On the Vista machine:
- The wireless connection IPv4 properties are set to use 192.168.0.1 as the DNS server
- The default gateway is set to 192.168.0.1 under the 'advanced' options.
- DHCP is enabled
This configuration worked previously using 2 XP machines. Connecting the aircard to the Vista machine isn't an option (XP machine is used by several people, Vista is a personal machine).
As mentioned, the networking between the two machines is fine, just no internet connectivity for the Vista box. Any help would be greatly appreciated.
Mike
