<~----> XP instal DVD not seen - Hardware Canucks
Old November 8, 2008, 05:39 PM
Default XP install DVD not seen
So, my new system needs a windows xp pro. I have a legally obtained iso version, I burned it to a dvd an when I try and boot the system all I get it "disk book failure, please insert system disk and press enter"
Ive done a couple of windows installs before, and never had this trouble....
any clues?
Desktop "APRIL"
CPU: Intel Core Duo e8400
Motherboard: ASUS P5N-D
GPU: BFG GTX 260 OC Memory OCZ Reaper PC8500(2 X 1gb)
Case: Antec 900]
PSU: CoolMax RM-750
Storage: WD 500gb SATA; WD 1tb SATA
Old November 8, 2008, 06:11 PM
CMetaphor's Avatar
Quadfather
Bad disc aka frizbee? Try burning at a slower speed if you're using generic blank DVDs.
Old November 8, 2008, 06:24 PM
kirk_d's Avatar
I going to start off with the obvious, is the dvd set to boot first in the bios,
Opty 170(naked) @2600 | Abit AT8 32x | EVGA Vanilla 8800gt 650/1625/950 | 2gb Ocz Pc4000Eb@260 | Audigy Gamer | Tx650 | Cm690 |
WC Loop: DD Cpx-Pro | HWL 240 Xtreme | D-Tek V2
Old November 8, 2008, 06:30 PM
yes lol, the dvd is 1st in BIOS(although only CDROM appears? (I'm assuming this just means the disk drive?)). I'm burning using a different program and brand dvd now!
Desktop "APRIL"
Case: Antec 900]
PSU: CoolMax RM-750
Old November 8, 2008, 06:38 PM
kirk_d's Avatar
If your iso came with a checksum, make sure your burn matches the value!
If it doesn't, it's another coaster
Old November 8, 2008, 07:46 PM
hmmm, tried with nero 9 and the same message. I've no clue lol!
Desktop "APRIL"
Case: Antec 900]
PSU: CoolMax RM-750
Old November 8, 2008, 08:55 PM
OK, several burning programs later and another ISO later, it could read it. thanks all!
Desktop "APRIL"
Case: Antec 900]
PSU: CoolMax RM-750
