<~----> Vista 32bit or 64bit for gaming - Hardware Canucks
Old October 21, 2008, 03:26 AM
Default Vista 32bit or 64bit for gaming
Which O/S is better for gaming? Vista 32bit or 64 bit?
Old October 21, 2008, 05:53 AM
DK2 DK2 is offline
If you don't believe 64bit is better, then you believe 32bit is better..... something like that.
Old October 21, 2008, 05:56 AM
Xilikon's Avatar
64 bits is better since it can use all 4 Gb or more of RAM while 32 bits is a bit more limited. Also, at this point, there is no reason to buy 32 bits since the 64 bits version works great.
Xilikon - Team 33
Proud to be [H]ard !
Old October 21, 2008, 11:28 AM
32bit is fine as games are only written in 32bit and can only address 2gb of memory.
Ask Dan: What&#39;s with the 3Gb memory barrier?
Old October 21, 2008, 12:36 PM
DK2 DK2 is offline
the only game I know of that has a 64bit version is Crysis, and it comes with both 32 and 64bit.
We may start to see more dual releases in the coming year though.
What will make the difference is somebody writing a game engine that really takes advantage
of 64bit, rather than just a re-compile of code.
Then we'll have a 64bit only game, and we'll just have to wait and see who jumps first.
It's debatable which is best for gaming.
Old October 21, 2008, 05:16 PM
Half-Life 2: Lost Coast is 64-bit as are several other Source engine games (not that you really need it w/ the Source engine) ...
32-bit is nearing obsolescence ...
Old October 21, 2008, 05:20 PM
32bit is far from obsolete.
Very few people are programing for native 64bit yet. We have a long ways to go before that.
Old October 21, 2008, 05:33 PM
MpG's Avatar
MpG MpG is offline
32-bit will be around for quite some time, especially if M$ makes the next windows in 32 and 6-4bit flavours again.
I'm not sure if any games out right now breaks the 3.x GB memory barrier right now. Maybe FSX? There are a couple that break the 2GB barrier, but that's about it.
Old October 21, 2008, 05:47 PM
Actually didn't Microsoft say that Windows 7 would be 64bit only back then ?
Some people on Guru3d Swear by VISTA 64 and say that even for 32bit games it runs better than Vista32 !
Old October 21, 2008, 05:49 PM
Most of it is a Placebo effect . and there is very little difference in performance.
Windows 7 is not going to be strictly 64bit it would be shooting itself majorly in the foot.
