Old October 21, 2008, 06:13 PM
Well, my new rig is going to be geared for gaming. CPU will be at least an E8600, but most likely be a 9650 or higher. GPU will either be a 4870x2 or GTX 280 Motherboard is going to be an ASUS Rampage Extreme. So i believe everything will allow 64bit. Would it be worth installing Vista as 64bit now or should I stick with the 34bit install? Like I said, this rig will mostly be used for gaming.
Old October 21, 2008, 06:16 PM
Just get 32bit.
Old October 21, 2008, 07:04 PM
DK2 DK2 is offline
I would disagree enaberif, if it’s a new system just get 64bit, its going to change
someday soon, the problem is when? When it does change, everything will be 64bit.
Getting 64bit covers you both ways.
Old October 21, 2008, 07:18 PM
Originally Posted by DK2 View Post
I would disagree enaberif, if itís a new system just get 64bit, its going to change
And I disagree with you.
64bit mainstream isn't going to happen anytime soon.
Only reason why people are running 4gh or more of memory is simply cost.
As the old saying goes.. if you have to ask you don't need it.
Old October 21, 2008, 08:07 PM
Eventually there is going to be a limit as to what you can do with 32bit - as games get more agressive and memory requirements get bigger, the move to 64bit might be sooner than you think! A 32bit OS can only address 2GB of RAM at once (meaning application or games). So what happens when you start to see huge textures, and graphics cards with 1 GB and 2 GB :) soon your graphics card might have just as much or more RAM than your system RAM :) I'm even worried about the x86 architecture, I mean I think we've almost reached its limits and I don't know for how long are chip makers going to keep with the x86 architecture, which has a limited life, and will eventually end soon, the same way Win9x has ended and people moved on to an OS that can support more than 1GB of RAM :D
Old October 22, 2008, 01:57 AM
I disagree with your both:P 64 bit has been mainstream for YEARS. Just not with the little boys. And besides, 64 bit can run 32 bit LoL. Tink logically, 64 bit will hit the drive LESS for ram cache:P It can address the whole 4 GB or more, load the ENTRIRE map into cache, reload levels faster, get killed faster LoL
And still run 32 bit apps when not gaming
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old October 22, 2008, 04:58 AM
DK2 DK2 is offline
I could swear half of my post is missing, hmmm, another thread maybe, or just crazy. :)
Old November 1, 2008, 10:52 AM
nam's Avatar
nam nam is offline
vista 64 is the one to get if you have 4gb as 64bit makes use of all ram .unlike 32bit
  #19 (permalink)
Old November 1, 2008, 10:56 AM
"Quote This..."
If you are going to run vista then get 64 bit. It's not my main os but I have yet to have any problems with it.
That said, I do all my gaming in xp 32. still faster and smoother than vista 32 or 64.
  #20 (permalink)
Old November 9, 2008, 08:16 AM
486's Avatar
486 486 is offline
Easy choice. If you want 32-bit system, then stick with Windows XP. If you after 64-bit one, then Vista 64 is your choice. Vista 32-bit is useless, especially for gaming.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
