-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Catalyst 8.10 (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/10900-catalyst-8-10-a.html)
Eldonko October 15, 2008 12:44 PM
Catalyst 8.10
It is now up, get it here.
New features:
Catalyst Control Center™ Fan speed control
This release of the ATI software driver version 8.54 introduces the ability for users to control the speed of the GPU fan when running in accelerated graphics.
Force Component Video Detection
This release allows users the option in Catalyst Control Center to force Component Video detection in the Display Options aspect. By selecting this option user are able to adjust the Component Video property settings (without a device being physically attached) allowing user to change format and frequency to a desired value. The selected values will be applied to the display once a component video display device get connected. The feature is applicable for all AMD products supporting Component Video.
Release notes
miggs78 October 15, 2008 12:57 PM
Thank you Zac!! .
WolfBane October 15, 2008 02:42 PM
Thankyou kindly:)
Brian October 15, 2008 08:04 PM
Is this for all the Radeon cards? Or just specific ones that the new 8.10 came out for?
Killswitch October 15, 2008 08:34 PM
Yup, it's for all of them. Just click on 9500 at the bottom of the Radeon list and you'll see. :biggrin:
Brian October 16, 2008 04:30 PM
Since ATI is allowing you to do this (control the fan), it shouldn't void the warranty on the card or anything should it? Since it's them allowing you to do it...so if the fan wears out or something before the card's warranty is up.
Eldonko October 17, 2008 07:48 AM
No that will not void the warranty.
Eldonko October 17, 2008 08:49 AM
Have any of you that are running 3870s in CF tested 8.10? I cant get it to work, CF = instant bsod with ati driver error in both Vista and XP. Single cards work fine. Im starting to suspect it is the board so Im trying to find someone that can confirm that 8.10 and 3870 CF is working.
magictorch October 20, 2008 04:51 PM
Tried these out with 4870 in crossfire and got a boost of about 6fps in Crysis at 1900*1200:thumb:
BMWDriver November 8, 2008 11:36 PM
So how do you control the fan's speed ? I can't see anything in Catalyst Control Center...
