<~----> HELP! Wondows live messanger hangs on system startup ? - Hardware Canucks
Old September 30, 2008, 02:38 PM
Exclamation HELP! Wondows live messanger hangs on system startup ?
My windows Live messenger Hangs on system startup (it is set to sign me in automatically on system startup). I have to go into the task manager stop it then restart messenger for it to work. I have tried uninstalling it and reinstalling it but that didn’t work. I also tried the online help feature, but I couldn’t find the answered on there either. I am at a loss as to how to fix it. The version of windows live messenger that I have is 8.5.1302.1018.
Thanks
Old September 30, 2008, 05:16 PM
Jon_di2's Avatar
What are your system specs? What O/S are you running? Have you done a lot of spyware and virus checks lately?
I would clean the registry to start, and use a program like regedit to check which programs are set to start when you log into windows. But a simple solution would be to turn off automatic start up on windows live and just start it later.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old September 30, 2008, 06:56 PM
BALISTX's Avatar
I would just have it not start at start up. Chances are you could be having a lot of items starting up causing MSN to hang up. Do you really need to have it start at start up? If you can't get into MSN to stop it from starting up do the following:
Windows XP:
1. Click on Start and go to Run.
2. Type in msconfig and press Enter.
3. On the System Configuration window click on the Start Up tab.
4. Uncheck MsnMsgr and click on Apply and OK.
5. When prompted to restart the computer, restart the computer.
Windows Vista:
1. Click on Start.
2. In the Start Search field type in msconfig and press Enter.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old September 30, 2008, 06:58 PM
Infiniti's Avatar
For opening in vista, isn't it easier to do Startmenubutton+R to open up run and type in msconfig?
Old September 30, 2008, 07:01 PM
BALISTX's Avatar
Either way works.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old September 30, 2008, 09:03 PM
Well here are my system specs and nothing starts with MSN only AVG and I have did the registry cleanup and all that before posting
Old September 30, 2008, 09:16 PM
Jon_di2's Avatar
If you are virus free and no other problems are occuring on your computer, it could be a problem with Windows Live communicating with the internet. If your using a router, try to plug your computer directly into the modem. If this doesn't work and the problem isn't your router, then disable any firewall on your computer. Finally if you have a anti-virus that runs on start up, disable it. Do these one by one so you know which one is the problem.
Old September 30, 2008, 10:33 PM
ugh quit recommending msconfig PLEASE.
There are proper tools out there to remove things from your startup list properly.
Second you can go into msn messenger and tell it to stop from the options.
Old October 1, 2008, 08:03 AM
SugarJ's Avatar
Somehow I just knew Gameplaywarrior=49-parallel. This guy has played us for fools twice. Stop helping him.
Old October 1, 2008, 09:25 AM
You want to tell me how I played you for fool’s twice?
Once was at NCIX which has no connection (other then it is sponsored by NCIX or something) to this forum at all……I made an alternate account because 90% of you wouldn’t have helped me at all if I used this account…..your basing things on something that is not even connected to this forum
None of you said anything till I decided to abandon my other account…..I don’t like having to what I did, but it was the only way that I would have gotten any help from most of you (as I already stated)
