Old September 26, 2008, 04:15 PM
Default Ubuntu not booting
I just built a new computer. I ran memtest and a hard drive test on it, and passed all. I downloaded and made an install disk for Ubuntu 8.04 64-bit. I installed it using the guided setup without any errors. Now when I boot up my computer, however, it goes through all the normal startup bios stuff, then goes to a black screen with an entry cursor and stays there. What is going on, and what can I do?
Old September 26, 2008, 04:19 PM
sswilson's Avatar
Did you use the DVD iso or the CD iso? I had major problems with the DVD install ISO, but the CD one installed without any issues at all.
Did you try the live cd to ensure that your hardware is compatable with Ubuntu?
Old September 26, 2008, 04:21 PM
I used the cd iso, and I I ran the live cd first. it worked fine.
Old September 26, 2008, 04:36 PM
sswilson's Avatar
Not sure what to say then.... check your HDD settings in bios, and after that... if it were me, I'd try to re-install it rather than trying to figure out how to fix an install.
Old September 26, 2008, 04:49 PM
at the boot prompt:
Code:
boot noacpi <enter>
thats it.
Old September 26, 2008, 08:14 PM
I'll give that a try, enaberif. If it does work, will I have to do that every time?
Old September 26, 2008, 08:51 PM
NyteOwl's Avatar
no, you can add it to the bootloader's config file soi it's done automatically.
Obsolescence is just a lack of imagination.
Old September 26, 2008, 09:10 PM
Ok, . . another Ubuntu question. Can I install it with RAID 0? I had my hard drives set up in RAID 0 the first time, but it still made me choose one of the hard drives . . whats going on there?
Old September 26, 2008, 09:37 PM
It should detect the RAID setup automatically. Check the disk size when it asks you.
Old September 26, 2008, 11:03 PM
Ok . . . I unplugged my 2nd hard drive, reset my BIOS to the default settings, and tried to install from the Ubuntu 8.04 cd. It goes to a screen with a progress bar that goes back and forth. After doing this for a while, it shows up with the following text on a black screen:
[integer here] Buffer I/O error on device fd0, logical block 0
From what I read, this refers to the floppy drive, which I don't have. What can I do to fix this? I just want to get an OS installed so I can use my new computer . . .
Case: NZXT Tempest PSU: Corsair TX750 Mobo: Asus P5Q Pro CPU: Intel Q9550 Cooler: Arctic Cooling Freezer 7 Pro RAM: 4 GB OCZ DDR2-800 Video: Visiontek HD 4870 (790/1100) HDD: 2x WD 500 GB in RAID 0 Optical: LG Blu-Ray/DVD Burner combo
