  #31 (permalink)
Old September 21, 2008, 08:17 PM
Oversized Rooster's Avatar
Alright, I installed the 8.9 drivers. Both cards are still running well, and the same level of overclocking is possible (unlike 8.8 which crashed at even a 5MHz OC).
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
  #32 (permalink)
Old September 23, 2008, 09:03 PM
NyteOwl's Avatar
I see they still have the problem of crashing when you use the framebuffer for console on linux. :(
Obsolescence is just a lack of imagination.
  #33 (permalink)
Old September 24, 2008, 05:34 PM
Dr_BenD_over's Avatar
Fallen Folder
ODD, my HD 4870X2 runs 20deg hotter with 8.9 vs the beta's that came with my card.
All's well that's Haswell
  #34 (permalink)
Old September 24, 2008, 05:51 PM
Infiniti's Avatar
I was just wondering if its okay to install 8.9 over 8.7... My CoD4 keeps on crashing, and it says that the video driver is crashing, so installing new drivers might fix the problem.. right?
