Old September 15, 2008, 12:44 AM
CTA's Avatar
CTA CTA is offline
Default bookmarks- where?
i am trying to find bookmark from FF3 and Opera9 and can't find one... i only found my IE6...
so can you please tell me what is the address to bookmark folder of both browser, Opera9 and FF3...
or even link bar (i believe its a folder in bookmark folder.. right...?)
i am trying to transfer all list of links (shortcut icons) and merge into one... then organize it... becase its damn messy :|
<< wish to find a non-browser bookmark/favorite list software then it would be easy to organize... anyone knows if it really exists...?
Old September 15, 2008, 06:45 AM
Jack Rabbit's Avatar
Are you using Vista? They are probably in the fancy new hidden data directory in your home folder.
- James Graham
Old September 15, 2008, 09:43 AM
In Opera, click on Help > About Opera and it will tell you where your bookmarks folder (just copy & paste the address into a Windows Explorer window)
For example - C:\Users\James\AppData\Roaming\Opera\Opera 9.52\profile\opera6.adr
I uninstalled Firefox about a week ago because I never use it, so I can't help you out with that ...
Old September 15, 2008, 02:28 PM
JD JD is offline
For Firefox in Vista:
%appdata%\Roaming\Mozilla\Firefox\Profiles
If you copy the entire profile folder, all your settings, addons, etc will stay assuming you copy the whole profile back over.
Old September 15, 2008, 05:42 PM
CTA's Avatar
CTA CTA is offline
i use win xp x64 ( i should tell early)
jmac, thank you, i found... but its very different than IE7 favorite folder o_O (how to export the links or import link into IE7?)
jdrom17, i did check %appdata%\moxilla firefox\ but can't find... (just curious why "roaming"?)
Old September 15, 2008, 06:11 PM
"roaming" is part of the fancy new Vista data folder stuff...
Basically, it is like the XP app data folder except there are at more of them. I guess complexity makes things more simple.
- James Graham
Old September 15, 2008, 06:12 PM
Pike's Avatar
Mozbackup is an awesome tool for backing up bookmarks, add-ons, settings, etc.
Old September 15, 2008, 08:44 PM
CTA's Avatar
CTA CTA is offline
ah i see... i thought its modzilla or something ;p
thank pike, i will look up at mozbackup (can it work on opera ;p)
Old September 16, 2008, 05:30 AM
Pike's Avatar
In case you need the link....MozBackup - Backup tool for Firefox and Thunderbird
