-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   freezing at saving your settings..... (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/10077-freezing-saving-your-settings.html)
rob123 September 14, 2008 07:54 PM
i put together s system this weekend. it has developed a really annoying fault. everything goes well until i elect to shutdown.
the system hangs at "saving your settings". i have trolled the web for hours trying everything i could find. i even tried a little file downloaded from microsoft. all to no avail.
have to shut down the system by pulling the plug. there has to be an easier way.
no norton installed
windows xp home with nearly all updates ( wont update anymore either)
zone alarm internet security suite with anti virus installed
very little else.
any help would be appreciated
rob123
Jmac September 14, 2008 10:15 PM
The first thing I would do is disable all 3rd party programs and services.
To do this:
Start > Run .. > msconfig > Services tab > Check "Hide All Microsoft Services" > Click Disable All > Click Apply > Startup tab > Click Disable All > Click OK > Restart your computer.
This is just for diagnostic purpsoses, so note that not your anti-virus will not be functional (don't start hitting up porn and warez sites immediately after the restart :P) and some of your hardware may not function until you reenable the necessary startup programs and services (i.e. webcam, scanner, etc.)
If you no longer experience issues, you're going to have to go through the arduous task of determining which services/program(s) is causing the issue. If you are still experiencing issues, you're going to have to do further diagnostics to determine whether you have a hardware issue or a corrupt OS. If hardware, it's likely related to the memory or hard drive. I would first try Start > Run ... > cmd > chkdsk /r c: It will check for disk errors on your main partition and attempt to fix them. Note that it may take several hours, so schedule it for a period where you won't be using your computer (i.e. over night or while at work).
Oh, and you don't need to pull the plug; just hold the power button down for 5-10 seconds and it will shut down.
rob123 October 12, 2008 01:45 PM
sorry, i just remembered this post. it seems that the problem has solved itself. the system in question takes 20 or 30 seconds to shut down but at least its faster than it was.
thc
rob123
enaberif October 12, 2008 01:58 PM
thc
rob123
Regardless.
Do yourself a favor and get rid of Zone Alarm its a piece of crap and just enable Windows Firewall.
Then install Anti-Vir for a virus scan.
