Old September 13, 2008, 03:20 PM
Dar_ell's Avatar
Default CCC problem
So yea, i been hearing 8.7 catalyst perform better then 8.8. So i looked around and saw that Driver cleaner pro was a good way to clean the drivers out of my system. I clicked to remove all the ATI drivers,after it was done i restarted then installed 8.7 catalyst. For some reason i cannot open CCC. here is a screen shot of what happened. http://i38.tinypic.com/fceu1.jpg . My display drivers and everything else works fine, its just the CCC (please someone advice fast, without my custom profile my card is running 86C... it might not be bad but i don't like my card running that hot lol). Never mind fixed the problem. mods can delete this post if they like
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old September 13, 2008, 04:06 PM
Maybe you can tell us what you did to fix the issue. Could help others :wink:
Old September 13, 2008, 04:55 PM
Dar_ell's Avatar
Alright first i ran around crazy cause i thought i had to reformat. Then i tried uninstalling everything and w/e and installing 8.8, it didn't work. So i looked on google, no good answers (surprisingly). Then i went into C:\ATI\SUPPORT\8-7_vista64_dd_ccc_wdm_enu_66000\Bin64, and tried the install manager. i don't remember it fully but after trial and error of installing and uninstalling everything ATI on my computer it worked.
Old September 16, 2008, 02:30 PM
RCKage's Avatar
Trial and error rocks!
"And thus I clothe my naked villany
With odd old ends stol'n out of holy writ,
And seem a saint, when most I play the devil."
Old September 17, 2008, 09:52 PM
NyteOwl's Avatar
It works for Microsoft :D
Obsolescence is just a lack of imagination.
