Old September 9, 2008, 11:36 PM
why spend $95 on a case that comes with a PSU that your going to change out? Your wasting money that you don't need to.
I'm going to suggest looking into another case.
Old September 9, 2008, 11:40 PM
Dashock's Avatar
He does seem to have added a power supply to the list so i have no idea why hes getting that case in purticular .
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 10, 2008, 08:37 AM
Originally Posted by Synth View Post
Everything looks good, except for the motherboard and case :
1. Make sure your HD4870 x2 will actually fit in the case (case came out in 2005... looks smallish)
2. Maybe Biostar I45 or Asus P5Q-E over the P5Q-Pro...
My .02
Either one of those boards are good, go with the cheaper, you won't regret getting any one of those.
SugarJ's Avatar
He likes the look of it. I just encouraged him to make his own choice of cases. I know what I like, but for a first build, looks matter more to the builder. After you've banged your knuckles a few times and cut holes to hide wires, your priorities seem to change. If only the 690 came with a side window.
Old September 10, 2008, 11:00 AM
I understand that but why not go with something like the TJ04? Its a great little case with a side window?
NCIX.com - Buy Silverstone Temjin TJ04B Black ATX Case 4X5.25 2X3.5 4X3.5INT No PS - TJ04B In Canada.
Its a few dollars more but at least it doesn't come with a PSU?
Old September 10, 2008, 11:25 AM
Oh and Sugar, man it has now become much easier to make a window on a side panel, hek you can even use double sided tape, the heavy duty one that bill owen suggests, and it works like charms, even a dremel can do a job, with some molding and plexiglass, that is the only thing that you might have to shop on the other side of the border, like performance pcs.
Old September 10, 2008, 12:19 PM
cwestwell's Avatar
I agree with most. That case chassis is old and flimsy (I had a similar raidmax case) it would be well worth it to spend and extra $30 bucks to get a more up to date case your 4870x2 will fit but it will almost be in one of the 5.25 drive bays if not slightly inside. Get an antec 900 or CM 690 for a better case that is not to much more money or if your sold on the silver the Lian Li PC-65
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
Old September 10, 2008, 01:26 PM
spend an extra $8 and get a bolt through kit while your at it makes installing the heatsink so much easier not to mention having the cpu run cooler
