Old September 3, 2008, 09:16 AM
Arrow New Gaming System *HELP*
Hi, I am planning to build a new system by myself (first timer). I am going to list some of the compoents that I will use. Let me know if there is anything that I can change.
CPU
E8500 or Q6600
Mobo
EVGA 750i FTW or 780i FTW?
GPU
2 x EVGA GTX260 SC+ in SLI ($269.99each)
1 x EVGA GTX280 OC ($469.99)
2 x EVGA 9800GTX+ in SLI ($169.99each)
PSU
Corsair HX1000
Cooling
Thermaltake 680l Water System
Case
Thermaltake VH6000BWS ARMOR+
RAM
Some DDR2 with 1066MHz or higher?? I am not sure.
HDD
2x Seagates 640GB in RAID0 maybe or just 1
Thanks in advance for helping!
Old September 3, 2008, 09:24 AM
First question, does the wire for the front I/O (USB or FIREWIRE) come with the motherboard or the case? OR do I have to purchase them separately?
Old September 3, 2008, 09:45 AM
Dashock's Avatar
If i understand you correctly the wire comes from your case which you then connect to your motherboard like in my Cosmos S case it has support for both which i then connect to the board.
Alright first choice of hard drive is good I have not bought and of the new 640gb seagates but if they are anything like the 500gb versions then you have a solid performer. For ram may i suggest the Mushkin Ascent 8000-8500 4gb kit. What windows will you be running??
You'll have a beast of a computer with any of those Videocards i was questioning the use of that 1000 watt Powersupply but if your going to go sli then i guess it is good to have that extra boost.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 3, 2008, 10:21 AM
1Tanker's Avatar
CPU
E8500 or Q6600
Mobo
GPU
PSU
Corsair HX1000
Cooling
Case
RAM
HDD
Looks good, except for cooling. What do you plan to cool with the TT? I highly doubt that water-cooling setup will cool a Kentsfield and 2 powerful GPU's. GL
Old September 3, 2008, 10:37 AM
cegras's Avatar
If I may suggest, techreport says that there are 45nm quad cores listed which may very well be at the old price point of the Q6600.
Intel intros $230 Core 2 Quad Q8200, new Core 2 Duo - The Tech Report
For cooling, that's no better than a good air cooler. A xigmatek HDT, vendetta 2, or TRUE would be better (with a good fan). And would cost a little less.
For harddrives, the Western Digital 640 is currently the defacto hard drive of choice.
If you're not so banged up on SLI, a P45 mobo + 4870 would be well suited for you. I don't personally know, but it seems in general that nvidia's chipsets are inferior to intel's current ones.
Case is your choice for aesthetics, but I prefer minimalist ones. The P182 / some cooler master cases are worth looking at. Or LianLi.
Old September 3, 2008, 10:40 AM
CPU
E8500 or Q6600
e8400
Mobo
Asus P5Q
GPU
1 x EVGA GTX280 OC ($469.99) - depends on monitor size
PSU
Corsair HX1000
Corsair 750w or PC P&P 750
Cooling
OCZ Vendetta 2
Case
Coolermaster 590/690/Haf; Stacker 830
RAM
HDD
RAID not worth it; buy a small drive and 1 large drive
Old September 3, 2008, 10:42 AM
Thanks that's what I need to know.
I am just using the TT to cool the CPU, was hoping to get some good overclock.
Old September 3, 2008, 10:44 AM
You don't need 1000w for SLI.
And SLI is really a waste of money with a single card solution that can push a 24" no problem.
Old September 3, 2008, 11:42 AM
I going to be running 25.5" 1920x1200 resolution.
Is q8200 already out?
Old September 3, 2008, 01:08 PM
cegras's Avatar
Don't use the TT. A TRUE or HDT solution will work much better.
As for that resolution .. a 4870 should be 'just enough' - you'll probably want more headroom though.
NCIX.com - Buy Intel Core 2 Quad Q8200 Quad Core Processor LGA775 2.33GHZ Yorkfield 1333FSB 4MB Retail Box - BX80580Q8200 In Canada.
