Old August 17, 2008, 12:51 PM
SmogTown's Avatar
Default Need help choosing a motherboard
I'm building a new system, mostly for gaming and need help choosing a motherboard. I have an Intel E8400 and want to get a Radeon HD 4870 X2 vid card. What motherboard would you recommend? I was thinking of a DFI LP DK X48-T2RS.
Old August 17, 2008, 03:36 PM
1Tanker's Avatar
If you want to overclock that baby(E8400), this Biostar seems to be a fantastic dual-core overclocker..and it has all the bells & whistles of the $250-$300 boards.
Old August 17, 2008, 03:38 PM
geokilla's Avatar
ASUS P5Q Pro.
Read the review on it at the front page. Great board for the price imo.
Edit: It's a P45 chipset.
Old August 17, 2008, 04:10 PM
werty316's Avatar
I also recommend the ASUS P5Q Pro.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old August 17, 2008, 04:39 PM
SmogTown's Avatar
Hey thanks for the recommendations .
Old August 17, 2008, 09:15 PM
Well good you asked the question here is a comment on DFI Mobo's and the 4870x2, seems like major issues down that path but I'm sure DFI will get it sorted soon enough:
Palit Radeon HD 4870 X2 2GB Video Card Review
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
