Old August 6, 2008, 11:12 PM
Kayen's Avatar
Default Criticize friends build before it's too late.
Ram-Mushkin - XP2-8500 Xtreme Performance DDR2 SDRAM (5-5-5-15), 4GB Dual Pack
HD-Western Digital - 250GB Caviar SE16 7200rpm SATA II w/ 16MB Cache
Optical-Samsung - SH-S203B 20X SpeedPlus(that tm thingy) DVD-Writer,SATA Black
PSU-OCZ - 600W GameXStream Power Supply w/ Quad + 12V
Mobo-eVGA - nForce 630i / e-Geforce 7150 w/ DDR2 800, 7.1 Audio, Gigabit Lan, PCI-E x16, HDMI,DVI-HDCP
CPu- Intel Core 2 Quad Processor Q6600 2.4GHz w/ 2x4MB Cache
CAse- Aprevia - X-Jupiter Jr. G-Type Case, Black
GPU- BFG - GeForce GTX 260 OC 896MB PCI-E w/ Dual DVI, HDTV-OUT
Total he gave me was $1012.60. Not sure if with GST or without. He's buying Local at MemoryExpress. (Memory Express Computers - Computer Parts & Laptop Computers in Canada)
So any suggestions, my suggestions were get a better mobo, and e8500 instead of Q6600, and another case.
EDit: price without GST.
Old August 6, 2008, 11:15 PM
cpu: e8400
case: 590/690
psu: corsair hx620
Old August 6, 2008, 11:18 PM
CTA's Avatar
CTA CTA is offline
why not use se16 640? its will be very good option than 250gb for 80cdn
if you are interesting in 9800gx2 for 289.99 OR
if you find a good deal for 4870 (visiontek is much better) then i highly recommend you to buy it...
ps. ncix.com ;p
pps. i suspect without tax
Old August 6, 2008, 11:22 PM
Kayen's Avatar
Yeah i told him NCIX.com ... he didn't listen . LOL.
Sigh what do i do now.
The 4870 there is $310..
Old August 6, 2008, 11:32 PM
and the e8400 is $167 ;)
Old August 6, 2008, 11:34 PM
Kayen's Avatar
Lol he keeps tellin me to chill when i gave him that suggestion. I told him to get he e8400 + 2x Arctic Cooling Freezer Pro 7(one for me : D)
Old August 6, 2008, 11:50 PM
Then tell him to buy his own computer.
If he's not willing to listen to sound advice from a friend.. he's not much of a friend.
Old August 7, 2008, 12:39 AM
Mibs's Avatar
Haha harsh.
What's up with that mobo choice? Why doesn't he get a nice P45 or other Intel chipset. I mean why get a board with integrated graphics if he plans on getting a GTX 260...
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 7, 2008, 05:58 AM
Dr_BenD_over's Avatar
Fallen Folder
I definitely wouldn't use that mobo, with a Quad or otherwise.
All's well that's Haswell
Old August 7, 2008, 11:27 AM
MpG's Avatar
MpG MpG is offline
I second the 4870 card. Same price, and a pretty definite edge over the GTX260 across the board. Ditto for the HX620 PSU. And the motherboard... why?
If doesn't like the advice in this thread, tell him to give some reasons WHY. If he was getting some of these parts for free, that'd be one thing. But pretty much every suggestion here comes with definite reasons behind it.
