Old August 3, 2008, 09:14 PM
Default Power requirement question
Hi,
I am putting together a new build and wonder if I will have enough power with my existing Corsair 620 Modular PSU, I have had it about 18 months and it is amazing but the system it was running had a 7600gt in it.
My specs will be:
Q9550
Asus P5Q Deluxe
Mushkin Ascent 2x2gb
1x320 Seagate
2x640 WD
5x500 WD
2 DVD Drives
1 Fan Controller
1 X-fi Platinum
3x80mm Fans
1x120mm Fans
Now the question mark... 1 GTX 280
Thanks for your thoughts.
Old August 3, 2008, 09:27 PM
andynerd's Avatar
it may work http://www.tomshardware.com/forum/25...r-requirements
Old August 3, 2008, 09:41 PM
SugarJ's Avatar
Try this power calculator, add at least 100w for headroom. You don't want your PSU maxed out all the time.
eXtreme Power Supply Calculator Lite v2.5
Old August 3, 2008, 09:42 PM
Originally Posted by Starkness View Post
Hi,
My specs will be:
Q9550
Asus P5Q Deluxe
1x320 Seagate
2x640 WD
5x500 WD
2 DVD Drives
1 Fan Controller
1 X-fi Platinum
3x80mm Fans
1x120mm Fans
Personally you should be ok but to be on the safe side I'd say 700w minimum.
Old August 3, 2008, 10:17 PM
Hi,
My specs will be:
Q9550
Asus P5Q Deluxe
1x320 Seagate
2x640 WD
5x500 WD
2 DVD Drives
1 Fan Controller
1 X-fi Platinum
3x80mm Fans
1x120mm Fans
More than enough.
See the system in my sig? HX520 power it all no probs.
Add an HD 3870 X2 to that i ran for a bit, or the two different GTX 280s.
And mine's 100w & 10a on the +12v less too.
Gigabyte X58A-UD3R | i7 930 | Corsair H50
G.Skill RipJaws 4x2 GB DDR3 | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
Old August 3, 2008, 10:53 PM
lowfat's Avatar
people always over estimate the power they require. For some reason people seem to think they need a 800w power supply for their rigs when they don't.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 4, 2008, 12:06 AM
I wasn't over estimating, just checking as nvidia says I need 550w to run the gtx280, which seemed kinda high to me, which is why I asked.
Old August 4, 2008, 01:49 AM
Jackquelegs's Avatar
HX620 is easily enough. The Nvidia recommendation is for a complete system (their test system of some sorts) and around 600W is perfect for it. Mind that you do have a LOT of harddrives.
Old August 4, 2008, 01:53 AM
Hence why I recommended a 700w minimum ;)
Old August 4, 2008, 08:54 AM
OK thanks, I was hoping to avoid the purchase of a new power supply, the upgrade planned is at the max of the budget, maybe I will just get a gtx 260 instead. Then I won't have to worry about power. When I bought the 620 it was to last me many years, not 18 months LOL!
