Old July 27, 2008, 08:15 AM
JD JD is offline
Originally Posted by serenity View Post
NVIDIA chipsets aren't all that stable so it's up to you. Intel chipsets are known for being stable and without issues.
k maybe I'm being too specific now, but that would look sooo cool to have all red fans and LEDs... it would match the front quite nicely.
What's the best way/place to find red LED PSUs and fans??
You won't be finding a decent PSU with red LEDs in it, so that would require modding if you really want that. For just LED fans, that's pretty easy to find:
120mm: http://www.ncix.com/products/index.p...ufacture=ANTEC
Doesn't look like NCIX has any 80mm Red LED fans though.
If you don't mind ordering from the USA, then these would probably look nice:
80mm: Blackfire4 UV LED 80mm Fan Sleeved - Red Products Model: ACR-BF4661 [ACR-BF4661] : Performance-PCs.com, ... sleeve it and they will come
120mm: Blackfire4 UV LED 120mm Fan Sleeved - Red Products Model: ACR-BF4685 [ACR-BF4685] : Performance-PCs.com, ... sleeve it and they will come
Just make sure you buy the same brand of each red LED fans since the red colour varies between companies.
