-   -   Router build critique (http://www.hardwarecanucks.com/forum/new-builds/8790-router-build-critique.html)
Cheator July 24, 2008 09:47 AM
Hey guys.
I'm going to be building a low power router for my new house. Its going to be my bro and I plus a roomie, and all 3 of us will most likely be using the internet to the max.
Because of this, I want to have a decent router to handle:
  • DHCP Server
  • Torrents (I NEED the latest distros!)
  • IP Tables firewall
  • MLPPP connection
  • Major QoS for VoIP
For this task, I selected the recently released Atom (I can't wait for Bobcat). Here is my build:
I know Untangle's requirements are high, but I was under the impression the Atom would still function decently. Can anyone tell me otherwise? And do you think this would handle it well enough? I am fairly sure it will but other opinions are always good!
Tazer-[X] July 24, 2008 09:55 AM
Personally, I would go with a really old P1, or even a 486, and run OpenBSD. THats a real waste of money there. Not that I would have any Idea on what im talking about though, im not 12 on a pc LoL
Cheator July 24, 2008 10:01 AM
Well I am looking to make it as low powered as possible since we'll be paying the electric Bill. Plus I don't have an old rig like that.
CMetaphor July 24, 2008 10:04 AM
think that should be powerful enough, judging by the hardware requirements for untangle.... It may, in fact, be overkill. Maybe a VIA-based all in one system like the Artigo would be cheaper and more "router-like" for you?
Cheator July 24, 2008 12:49 PM
It looks nice but 300 bucks is more than I wanna spend. That, and it only has 1 lan port. Nice unit though.
Tazer-[X] July 24, 2008 01:13 PM
You can get 'old' hardware like im talking about. Its alver the place. Heck, buy it from the papers. You dont even need more than 8 bit. That means no fans, it can even be rin from a few mb.s of disk space.
Cheator July 24, 2008 01:21 PM
It consumes much more power than the atom though.
JD July 24, 2008 01:36 PM
Are you doing a true MLPPP connection or just single link to avoid throttling? If so, do tell me how you get that setup on whatever OS. Right now I have pfsense running on my Sempron that I had kicking around and it seems to be working pretty decent but there's no official MLPPP for it and I know nothing about BSD.
Cheator July 24, 2008 01:43 PM
MLPPP is available for any distro.
I will be doing 1 connection at first, then maybe 2 eventually. the ISP I work for also might be installing a DSLAM near me and if so, I'll have 2 20 meg lines :clap: I hope :rofl:
Tazer-[X] July 24, 2008 05:54 PM
LoL, than why get pigeons to do all your transfers and squirells inspect all your messeges?
:clap:
