Old July 17, 2008, 05:48 PM
Default help a poor student
I have a 939 amd with 2.4 X2 cpu with 2x1GB ddr1 400 -would I benifit from a upgrade.
Here is what I have. 8800gt 512-just got it replaced a 7800gt
case powersupply harddrive-sata true 120 extreme heatsink
needed new cpu motherboard ram
Budget 300.00
used is ok -ebay forums etc.
This is what im looking at
OCZ Platinum XTC REV.2 PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-15 240PIN DIMM Dual Channel Memory Kit
$59.99
AMD Athlon 64 X2 5000+ Dual Core Processor Socket AM2 2.6GHZ Retail Black Box No HSF Unlocked
$79.99
Abit NF-M2S mATX AM2 GEFORCE6100/NF405 1PCI-E16 2PCI SATA2 RAID Video Sound GBLAN Motherboard
$64.45
Old July 17, 2008, 06:13 PM
misterd's Avatar
You're not going to see a HUGE improvement going from 939 to AM2 - also you didn't say how much memory you did have before (regardless of keeping it) Also buying the Black Box means you still need a CPU Heatsink of some sort.
If you can handle it - this would be my short list.
Intel Core 2 Duo E4600 Dual Core Processor LGA775 $142
ASUS P5Q Pro ATX LGA775 P45 DDR2 $139
OCZ Reaper Hpc Edition PC2-9200 2GB 2X1GB DDR2-1150 $45 after rebates
$326 before tax @ NCIX current sale - the shipping depends where you are. Hope this helps out a bit - the board is a bit overkill but should last you a good while and be a much bigger jump then your suggestion.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old July 17, 2008, 06:16 PM
Cptn Vortex's Avatar
I have a board for Sale. http://www.hardwarecanucks.com/forum...-am2-mobo.html
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS/USB3.1
i7-5820K @4.4GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old July 17, 2008, 06:20 PM
magictorch's Avatar
mmm I'm about to remove my P5KE wifi this weekend to make way for a 4870 and DFI x38T2R. I'll need to test the MB before I can sell. I also have some Mushkin HP 8500 2x1gb with strong D9 micron modules. If all gos well I can ship the lot for 130 if you want. Then you have enough for an E8400 with a few more dollars. If your interested I can post signed pics of the items.
Anyway if your not interested just get a decent gigabyte DS3L board on tp of that RAM.
Old July 17, 2008, 06:27 PM
Yes im interested
Old July 17, 2008, 07:35 PM
JD JD is online now
Yeah don't buy AM2...
If magictorch's awesome deal falls through, you could get something along the lines of this:
Intel Core 2 Duo E7200
Gigabyte GA-EP35-DS3L
2x1GB DDR2-800 (Mushkin, OCZ, Corsair)
That should be roughly around $300 and all new.
Would you mind listing what PSU you have though?
Old July 18, 2008, 06:57 AM
Exactly what I was about to suggest.
With your heatsink you'll be able to overclock that 7200 like mad
Old July 18, 2008, 01:35 PM
NCIX has a sale on E7200 should I jump on it.
http://www.ncix.com/products/index.p...l&promoid=1046
Old July 18, 2008, 04:50 PM
ok I jumped on it. For $129.98 it seemed like a good deal.
Old July 18, 2008, 05:03 PM
magictorch's Avatar
Yea I think that was a good deal. Youll have more fun pushing a 2.5ghz chip to 3.8 or 4ghz
