Old July 18, 2008, 05:17 PM
JD JD is online now
Could of grabbed the motherboard too since it's on sale as well:
http://www.ncix.com/products/index.p...e&promoid=1046
Old July 19, 2008, 08:10 AM
Im hoping for the Asus since I have had good luck with them.
Thanks for the interest.
Old August 2, 2008, 09:48 AM
Update time
Well I got all the parts and software installed.My computer is very fast now and I love it. I just wanted to thanks all that helped me.
I did try overclocking it but im not sure if im at 3.6 or 3.8 im new to intel
Old August 2, 2008, 10:21 AM
paphman910's Avatar
Originally Posted by magictorch View Post
mmm I'm about to remove my P5KE wifi this weekend to make way for a 4870 and DFI x38T2R. I'll need to test the MB before I can sell. I also have some Mushkin HP 8500 2x1gb with strong D9 micron modules. If all gos well I can ship the lot for 130 if you want. Then you have enough for an E8400 with a few more dollars. If your interested I can post signed pics of the items.
Anyway if your not interested just get a decent gigabyte DS3L board on tp of that RAM.
Wow, that is a good deal! You can't even get a P5K-E WIFI for under $145.00 without tax and shipping.
Paphman910
Old August 2, 2008, 10:33 AM
magictorch's Avatar
Ok great job so far. 3.6 is a very solid start Seems that board likes your cpu with that bios.
Anyway 400x9 is 3600mhz. Unless you have some of the power saving features it should stay that way. BTW be sure to follow the P5KE wifi guide I sent to ensure the system stays stable (eg disable execute disable bit, C1E speedstep). Play with the memory timings and dividers too when your more comfortable those are good modules I sent to you.
